Midsize truck shopping
I've read the Frontier has "heavy" power steering, but that might be because of people spoiled by EPS? I did read that the 4.0 spark plug replacement might be easier than the cheaper 2.5 but no idea.
Does the VQ40 have an internal water pump? I thought it was convention like everyone else's.
Another thing worth noting is the Frontier has something like a 13” diameter steering wheel whereas say a 3rd gen Tacoma is around 15”. I can’t help but wonder if some of this heavy steering is from an undersized steering wheel.
The internal water pump if true is somewhat of a disappointment. Change it when you’re supposed to I suppose and one should be good.
Internal water pump on a timing chain engine is kinda dumb but the previous gen VQ40 didn't seem to have problems.
All the previous Nissan VQ's use internal water pumps. They almost never give a problem. I have to assume the new 3.8 does also?
Nissan makes it possible to replace without pulling the timing chains - through an access cover. It has inspection covers you pull to put slack on the chain then you pull the pump out with a couple bolts. Its a little more involved than a Chevy V8, but not bad by current standards.
As for the steering, yes its a little heavy at low RPM. My wife and daughter have never said anything, so maybe you boys need to hit the gym. But honestly, I only notice it at all when trying to go lock to lock at idle, so I can't see that be a show stopper for anyone.
:ROFLMAO: To be fair, after only driving Toyota’s over boosted vehicles for the last decade, I might have been my own worst enemy. Trust me, I’ve long missed that on-center dead spot that my VW had.
I think the first three cars I owned were manual steering. I was sad that I couldn’t get my Saturn with manual brakes. That was about a lifetime ago… where does the time go?
I will also add on the water pump - even though its internal - its sealed from the oil with a double o-ring, and the front cover has a weep hole. so even if the pump leaks it in theory should never contaminate the oil.
Back in the glory days of Nissan Engineering.
https://www.thenewx.org/threads/water-pump-leak-diagnosis.285045/
From what I was reading, the access got removed on the 3.8L. It's still internal, but you have to remove the whole timing cover to get to it.
Seems like they did it right since it can't contaminate the oil like every other engine with an internal timing chain driven pump
Well, you all can feel free to laugh at me. My wife happened to find a 175k mile Jeep Jk 4 door with the 3.8. The price is cheap enough and it’s certainly nicer than my current daily.
It’s my understanding the 3.8 is fairly reliable minus the extreme oil consumption. The vehicle itself fits the bill for me too. 4WD, decent towing capacity.
We may look at it this weekend if it’s still available.
That wranger has a max tow rating of 3500 lbs, not really all that "decent" IMHO.
Well that's certainly a pivot, but a much cheaper option than a new/newer pickup!
Vehicles with short wheelbase like a wrangler are less stable with a load behind them. And the suspension which you want for great articulation is also not the same suspension you want with 650 pounds on the tongue. We own a RAV4. I would *not* want to put more than 2,000 pounds behind it. The unibody itself doesn’t feel like it would be up for the challenge. Put a 275lb male in the passenger seat and the whole vehicle rides funny. Likewise, I wouldn’t want more than 3,500 behind a 2 door wrangler just because they can’t even manage their own weight on a wet off-ramp in the hands of many drivers. 4 Door has a longer wheelbase, but again, a nicely articulating suspension can’t be stiffly sprung in the way you’d want for pulling 5,000 pounds - two different purposes.
A 2 door wrangler can only tow 2000 lbs whereas the 4 door is 3500 lbs.
I am torn between either a 3rd gen Tacoma or a 22+ Frontier. I like the Tacoma because of how simple and reliable it is, but sadly the only thing out there is now used. The new Frontier is a great little truck, but feels very cheap compared to a Tacoma. Being only a 2 year old platform, reliability is unknown. I can currently buy a highly optioned "base" Frontier for about the same price as a ~2-5 year highly optioned Tacoma, ($35k for both) but a huge turn off is no fender flares or wheel well liners. The truck will be used like a truck and see many muddy job sites and non ideal road conditions. My preferred Tacoma TRD Off Road package has both. I am currently driving 500 miles a week and my old Blazer is getting tired.
Any input is appreciated. Any other truck models worth looking into? Any input on a new Frontier vs used Tacoma? We just came back from a 5 hour round trip journey of looking at a Tacoma TRD Off Road that was a complete disappointment.
I recently began operating a 2024 Toyota Tacoma SR5 double cab as a work truck. It is a much higher quality, performing, and comfortable vehicle than the Colorado.
My personal vehicle is a 2021 Ridgeline and it suits me fine.
The Ridgeline is a fantastic vehicle, full stop. It is comfortable, relatively powerful, handles well, and has great utility. It even has a sophisticated AWD system and a reinforced unibody. It doesn’t deserve any hate.
There are few use cases where body on frame trucks do better, mostly relating to moderate+ off-roading or towing heavy. If neither of those are on the agenda, the Ridgeline is a great choice.
https://www.edmunds.com/car-buying/...yota-tacoma-trd-off-road-comparison-test.html
Go down to the paragraph titled "Making Sense of it All".
