How come?Since you already have winter tires, get the Defenders.
How come?
Thanks. Is that true for Defender2 though?Because they have a longer reported tread life and are quieter. if you don't need winter traction with both sets, there is no need to get the Cross Climates.
I live in Ontario, we get a couple of months of warm weather; it's too warm for winter set or too cold for summer. So I assume summers will wear our a lot faster.
That's what I have read too, which is why I'm leaning towards CC2Defender2 appears to be a good, long-life dry climate tire. Wet traction appears to be very lacking, at least according to TireRack's testing.
Just on the road? No light off-road? Gravel?2019 Toyota rav4
2019 Toyota rav4
In Ontario it is probably 10 years, not 6.How many km do you drive in a year? What is your tire size?
All tires, especially Michelin, will dry rot after 6 years. So if you don't do much driving, you don't need the longest-lasting tire, so in that case, get the best performing tire that will last as many km as you drive within 6 years. And remember, since you use separate winter tires, that also extends the life of your other set.
Summer tires are good over 40F/5C. How often is it warmer than that?
What other factors matter to you in a tire? Handling, ride, noise?
The UTQG ratings are B/A for the CC2, and B/B for the Defender2, which some people may find off-putting.
Is the Pilot Sport AS4 available in your size?
Does it have to be Michelin? There may be other all-season grand touring tires for you.
