Michelin CrossClimate2 wear concerns
Yep! Spent plenty $$$ on the set at Costco for our Prius V. Wore outer edges much faster. Got about 27k before started getting into secondary rubber. Costco wouldn’t do anything because Michelins written policy says have to be worn evenly across the tread. Michelin wouldn’t do anything because it has to go through an authorized retailer. Costco is one, but since they pointed the finger and Michelin and said I had to deal with them directly, I was out of luck. Still fairly upset about that. Had proof of alignment, rotation, balancing. I got stuck paying full price for the replacement set of tires.
How is it a Michelin issue when a customer doesn't inflate properly and/or has an alignment issue?
I have a friend who drives a lot of miles and she has a new set of CC2s. I’ll keep an eye on them. 4 cyl Camry so it’s not a very heavy vehicle or torque monster.
The Highlander is a pretty heavy vehicle. The Cross Climate 2 would not be the tire I would pick for that particular vehicle. The Defender would be a much better fit.
I run them on a 2015 Pilot not very worn in 35k miles. I presume it’s “heavy”.
I got my 28,000 mile set pro rated very easily from Discount Tire. They took a look, put it up on the alignment rack and told me they were replacing the set. Easy peasy.
Almost 19k on a set of CC2’s on the CX50 and the wear is even and minimal across all 4. Rotated every 8k based on the roads we drive. Door tag says to set “cold” pressures to 36psi. I set them to 35psi.
On rough pavement, they can be a little noisy. On smooth pavement, they’re quiet. In the rain, and I mean heavy rain, they’re outstanding! In the snow we had last winter, they were outstanding! It was a heavy, wet snow as well!
So far, they’re what I expected with a tire that has an aggressive tread pattern like that.
I stay on top of pressures too. If there’s a swing one way or the other, I adjust accordingly. We can have wild temperature swings in early spring and late fall.
I guess I’ll see what happens in the next 10-20k. 🤔
Are you or someone you love the victim of Michelin Dry Rot?
No dry rot yet. *crosses fingers
I heard they can be noisy, but they haven't been for me on this heavy 2014 AWD 5.7L 300 I use as a DD most times. I drive spiritedly too and not killed them yet. I do rotate them in the spring and fall f-r. They are wearing quite evenly, maybe a tiny bit from camber/driving style in front but rotations keeping that in check so far.
I've found like HemiBenny that they are quite good in the rain and especially slush. Pretty good in the snow for me, maybe could be improved a bit in snow stopping but its a big heavy car... still a lot better then the stock all-seasons that were on it (Michelins too, I can't remember which, but they were worse in every way but wore decently at least.) I do find they will follow grooves a bit more then the oems, but nothing bad. I set pressures about 2psi higher then door tag calls for and they are comfy decently quiet tires on most surfaces, maybe a lil boomy on grooved construction/badly potholed pavement (still far quieter then oems.)
I like them a lot so far, and will look into the CC3 when these wear more or start dry rotting...
Curious. Did you actually read my response? The car was aligned. I have receipts for that. I’d say most of us that care enough about our cars to be on this site keep an eye on tire pressure. I took it to Costco for the prescribed rotations and balance as well. How should that be my issue?
Was it both the inner and outer edges of the tire that wore excessively?
Just an FYI: Many cars come with alignment specs that can result in uneven wear under certain circumstances. The car manufacturers do that because the car handles better with those specs, but even if the alignment is within the range, you can get tire wear issues. My experience is that all the specs have to be within the inner half to avoid tire wear issues. Did I mention that many cars don't come with built in adjustment, so many alignment techs don't bother to adjust even if they are out of spec and don't tell the customer about the problem.
Mine are wearing like a chunk of steel. They also ride like wagon wheels and sound like I have 4 bad wheel bearings. Maybe a little hyperbolic, but not by much. Add in a 10% loss in fuel economy and these will go down as the worst tire purchase I ever made. My alignment is dead on perfect, tire pressure and balance are exact, they wore to 8/32nds pretty quick and now just live there. Mile after mile. I’ve had them balanced on a hunter as well as road force balanced and still deal with an 80mph vibration. I absolutely despise these tires! I see that they’re coming out with a cc3 and you can count me out. My local tire shop said they’ve had similar complaints and no longer recommend them. I’m glad they work for some folks, but coming from primacy’s there’s no comparison.
Hmm, my father in law had Michelin Cross Climate 2’s installed on his 16 Subaru Impreza. I haven’t noticed any excessive wear or vibration but it does make the car sound like all four wheel bearings are bad. My preference is for quite smooth tires. Fortunately it is my wife’s car now.
Yep. I have excessive negative camber in the back on BMW and it will wear out rear tires faster on inner side. BMW also recommends more aggressive camber.
I just rotate more often. But willing to trade that for handling.
It was. I know that should be a classic sign of under inflation, but I check regularly and that car has TPMS working. The original tires lasted longer than these and they all 4 wore same. We’ll see how the next set of tires wears and if it’s similar I’ll start buying less expensive tires.
Original tires are not some benchmark.
Manufacturers sacrifice performance for mpg or longevity.
The only Michelin tire that did not last 27k on my car was the Michelin Pilot Super Sport, and they should not last 27k.
That means they were under-inflated. Your factory OE tire pressure spec is what the manufacturer decided on for the OE tire and to give optimal ride quality. Different tires have different carcass designs and distribute the load across the tread differently, so if the outside or inside of the tread starts wearing prematurely then you need to adjust pressures accordingly for that tire. That was not a Michelin problem.
The city driving with a lot of turns may be the large factor. Going by my father-in-law's Renegade, all his tires wore very fast, like 1/2 the rated life. I had to adjust pressures to get decently even tread wear and edges definitely had issues. He is almost all around town driving.
I often try to avoid directional tires as I can't cross rotate. My sisters car wore left side a lot more from all the cloverleaf ramps she drives daily.
This^^^^^^^. I was lucky to get 20,000 on Michelin Energy Savers in city driving. Replaced with Defender 2's Initial impression. The Defender 2's track well and are quieter and smoother up to about 45. Jolting if the pothole is deep. The Defender 2's lose about 5% mpg city and 10% highway vs. the Energy Savers. 17 Camry. .02
I think the Dunlop PT20 oem tires on our Rav4H will need replacing next year. The CC2 was the tire I was eyeing. I’ll be watching these threads!
