96 Saturn SL2, driven mostly by my mother. I have 13,000 miles on the set of Michelin Hydroedge tires, and I have 8/32" remaining on all four.
There's no uneven wear on the tires (inner, center and outer all measure exactly the same). I run 40 psi in the front, 36 psi in the rear, OEM spec is 30 in the front and 26 in the rear. A 4-Wheel Alignment was done when the tires was installed.
I was expecting these tires to last much, much longer. The last set of tires were Goodyear Allegras that cost 1/3 less and lasted about 45k before they reached the wear indicators.
Is anyone else finding that Michelin Hydroedge tires aren't lasting much longer (if not shorter) than its competition?
