In Ontario it is probably 10 years, not 6.
It is not Arizona.
Krzyś
PS Probably longer if car spends time in garage and not basked in UV light all days long.
It's not Arizona, but it's still Michelin
It is not Arizona.
Krzyś
This^^^^^^^^^^^, but, If the CC worked, in snow, you would not have to mess with changing the tires out. .02Welcome to BITOG
The main purpose of the CC2 (and other tires like it) is to use one set of tires year-round, especially when snow is a consideration, when you can't afford winter tires or be able to store them, etc.
Since you already have separate winter tires, you don't need that.
If available in your size, I'd suggest the Primacy 4 (or the earlier Primacy 3) for your summer tires.
Agreed. It appears to be a 10-15% reduction in dry/wet stopping distances, which is noteworthy:A consideration between the two is that most report the CC2 cost them about 2 MPG.
Over the course of 50-60K this amount can be a considerable expense, in my case of a vehicle that gets 25 going down to 23 is almost enough to pay for a new set of tires.
One may feel the performance difference is worth it, others no way.
I think it depends on one's driving style. If one drives very conservatively and primarily drives in lower-speed, flat terrain - it may not be worth it?
They improved chipping resistance. Which was already good.the defender 2s are the same as the old defenders exept the siping is supposedly better and the compound changed a little bit. if you can find some LT defenders in the same size as your car tires i would get those, they last longer.
Based on the latest CR testing, it also has better wet performance than most other touring tires on the market.The main selling point of CC2 is winter performance.
I have a few suggestions for youI haven’t installed a better tire, yet.
I’m welcome to any and all suggestions in the sizes listed above.I have a few suggestions for you
(but I get your point)
