Here is the analysis on the original MMO from 2014 and comments about each component in MMO:
Marvel Mystery Oil - Analysis by University lab (Any element with 2 ppm or lower is not reported)
Phos - 631 ppm Use: Anti-wear
Potassium – 60 ppm USE: Buffer and weak detergent.
Viscosity – 2.3 cSt@100C, 7.9 cSt@40C Comment:
One very LV liquid! Due to light fraction Hydrocarbon Content. Flash Point – 143F
Hydrocarbons: Naphthenic Hydrocarbons Use: Oil Carrier and weak Solvent Mineral Spirits Use: A Medium Solvent
Chlorinated Hydrocarbons of orthodichlorobenzene Use: Strong solvent and decarbonizer.
https://bobistheoilguy.com/forums/threads/laboratory-analysis-of-mmo.221152/
General Comments:
1) MMO was originally designed as a fuel additive to help remove or reduce tetraethyl lead deposits created by the high lead content of previous era gasolines. Spark plugs might be good for a maximum of 30,000 miles because lead deposits would form shorts across the spark gap, resulting in misfires.
2) I do not recommend the use of MMO in the crankcase because the very low viscosity of MMO presents a problem for low viscosity oils in the XW20 range or lower, in that it reduces the oil thickness (viscosity), the Minimum Oil Film Thickness (MOFT) between reciprocating and rubbing parts,, and lowers HT/HS values.
3) IMHO, there are better fuel system cleaners out there with the PEA carbon dispersants included,
4) If you think you have stuck piston rings, or combustion chamber deposits, or sludge deposits, the High Performance Engine Cleaner (HPL EC) is currently the best engine cleaner available.
