I have a 2012 Chevy Cruze with a manual transmission. Many members on one of the Cruze forums have changed their transmission fluid to Amsoil Synchromesh and reported positive results (mostly improved shifting, less grinding on hard shifts). Along with a concern over inconsistent factory fill volume (incorrectly filled transmissions from the factory) I decided to follow their lead and change my OE fluid out for the Amsoil Synchromesh.
After driving for a few days now I can say the transmission does shift smoother than before, however...
This morning was pretty cold here in Ottawa, -26C (-15F). First shift this morning into reverse went smooth, smoother than it ever was with the OE fluid at this temperature. Once out on the street, 1st was very difficult to engage and the transmission fought me going into 2nd and 3rd as well just driving very slowly up my street. After a few minutes of driving shifting improved significantly.
The transmission has never before fought me all the way up into 3rd gear like that before with the OE fluid. It was a little stiffer than normal when this cold out, but never actually hard to get into gear.
The clutch was working fine. The clutch hydraulics in this car seem pretty much unaffected by temps down to about -30C (-22F), at which point it begins to feel a little stiff. This morning it was working perfectly fine.
So after two days of driving my impressions of the Amsoil Synchromesh are, better when warm, worse when extremely cold (~-25C, ~-13F), in this application at least. It is possible the transmission will improve as the Amsoil works into the transmission's bits, but I would think after several days of driving it's mostly there already.
Are there any manual transmission fluids (synchromesh?) that are known to work better at low temperatures? Do others have different experiences with this fluid at these temps?
