Originally Posted By: Garak
Originally Posted By: 757guy
Managing an aircraft weighing 600,000 plus pounds (870,000 Max Takeoff Weight), planning a descent from 35,000 ft. to reach a point where you could descend via a glideslope to the runway, managing power and airspeed to within +/- 2 knots (pitch controls airspeed, power controls rate of descent), taking out crosswind corrections, touching down within the first 1-3000' of the runway, deloying the thrust reversers, braking, and slowing while maintaining runway centerline is nearly impossible for someone who has not flown a large jet before.
I don't think this point can be emphasized enough. The difference between an airliner and a single engine, general aviation craft are astronomical. One must juggle a huge amount of things in an aircraft that is far more complex and bulky and fast (and a lot less forgiving) than a Cessana 150.
Even planning a descent from an operating altitude of an airliner is much, much more complex than doing so from a small aircraft. If you're out for a joyride and you want to land a Cessna 150, you can do so on a whim - you get your clearance and you land the thing. Or, if you change your mind and want to carry on or want to do touch and gos, it's ridiculously easy. In an airliner? Thanks, I'll stay in the back.
Originally Posted By: antiqueshell
As I've said earlier, I agree that landing a big jet would be a long shot, but if I were on that plane I would want to at least make the effort to save myself.
In such a scenario, I'd probably rather jump out the window than ride out a landing piloted by anyone who isn't a real airliner pilot.
Both pilots out. No way into the cockpit. Can't jump out the window since they ain't big enough or open.
So here is the "industry standard".
1: Pray
2: Bend way over.
3: Kiss your butt goodbye
