Major Problems after Seafoam
Chicago
Recently I ran about half a can of Seafoam through my egr port because Honda h22's are widely known to have them carb up. The hesitation I experienced before is completely gone now, but now I keep throwing random misfire cel's in multiple cyl's. I was already at about 1qt/1,500miles, but after the seafoam: I had a
"OKay guys, its official. The problem on my Prelude AND Accord fixed.
I just did this this morning, and I just drove the Lude for an hour trying to get it to bogg, but it wouldnt.
This is what I did
Remove coil and EGR Dump little more than 1/2 bottle of seafoam engine cleaner in EGR ports.
Most of it in the right side port closest to motor, little bit in the other one.
The dump the rest of the seafoam into a cup big enough to soak the bottom of the EGR valve in and let it sit. I used a tooth brush on the bottom of the egr to loosen up the real bad stuff. The replace the egr.
Let that #@$%! soak about 10-15 more minutes.
now I did this to prevent problems, prolly not needed. I pulled the plugs out and the ecu fuse and cranked the motor 10 or so times to get rid of excess. I dont think this step did anything, but I guess its how much seafoam you are going to be using.
Start up your car, be gentle for the first 5 minutes of driving, then hammer on the gas a couple times to redline.
I noticed it took about 10 minutes to rid the car of all the smoke, but now its so smooth, my car has no 2500 to 3k bog anymore.
and dont be fooled, I had no check engine light ever on my car. go figure.
Steve "
EGR was sticking open?
I'm going to have to take a closer look at the EGR as the problem on my rodeo. I have suspected EGR sticking open for awhile now. funny running problems. (idle not as smooth as it ought to be, a bogging rough running around 2500rpm)... I was thinking coils/ignition... or multiple problems all at once... replaced the ignition module and bought 1 coil pack to swap around.... After reading your post I may re-visit the EGR valve... cleaned it up a bit last year, but no soaks...
Well, more than it just sticking open..in our engines, the main egr ports get clogged up along with the metering ports in the intake manifold.
That hard carbon in the EGR runners dissolved in Seafoam? That's nice to know, I thought it required mechanical removal.
Could a piece of carbon become soft, flown through and stuck somewhere? Just a wild guess.
Is it possible to get enough misfires to trigger a code without feeling them?
so is it running better after u ran the seafoam through it or not? i am lost that u said it worked and now u say it didnt help the problem when i read further down on the replies?????
I have had my jeep ran great after each time i use a can of the stuff... or a 'lil less than a can.
how do u edit a post on here on the forums?
Try a can of STP Throttle body and intake cleaner on the egr valve. This stuff eats away carbon in my TB every time i clean the butterfly in the throttle body on my jeep.
Just a shot in the dark here but did you disconnect the battery for a while to reboot the computer?
It's possible that the Seafoam cleaned up something and now the computer is just confused...
Also, as BearZDefect said, it could be that a piece of carbon is now sticking somewhere-else. You could try another cleaning.
Also should mention, that after seafoaming a KIA we have here in the family, it started throwing a check engine light... I figured probably oxygen sensor throwing confused readings... We ran it around the block till the smoke cleared, disconnected the battery for a few minutes, check engine light gone.
I've always heard that after you "ingest" Seafoam you need to change the plugs, because dislodging/burning all of that #@$%! will foul them. I've also read of a few rare occurrences of the procedure ruining oxygen sensors.
yeah, i agree with changing the plugs. Seafoam is a great cleaner but it is pretty hard on the plugs if not diluted in gas.
Quote:
The problems mentioned in the 1st post including the misfire codes were after new plugs.
uuhmn, you got the plug wires right?? Thats the 1st I would check, I know me.
SeaFoam has a number of products. When you say SeaFoam, I'm thinking the one you put in the transmission fluid.
Is there one for adding to the gasoline?
