loss of power, but I am not sure if it is a wiring thing or an actual mechanical issue with the injectors. I can command them off at will. I wounder if the reading of "unrecognized state" means that they are open of with enough resistance for the computer to not be able to register? Never seen such a thing in my limited experience.
Fuel trims were way in the negatives.
These are all the Injector circuit DTC's, I'm almost positive they're set to "MIL on second error" in the calibration.
DTC P0201
Cylinder 1 Injector Control Circuit
DTC P0202
Cylinder 2 Injector Control Circuit
DTC P0203
Cylinder 3 Injector Control Circuit
DTC P0204
Cylinder 4 Injector Control Circuit
DTC P0205
Cylinder 5 Injector Control Circuit
DTC P0206
Cylinder 6 Injector Control Circuit
DTC P0207
Cylinder 7 Injector Control Circuit
DTC P0208
Cylinder 8 Injector Control Circuit
DTC P0261
Cylinder 1 Injector Control Circuit Low Voltage
DTC P0262
Cylinder 1 Injector Control Circuit High Voltage
DTC P0264
Cylinder 2 Injector Control Circuit Low Voltage
DTC P0265
Cylinder 2 Injector Control Circuit High Voltage
DTC P0267
Cylinder 3 Injector Control Circuit Low Voltage
DTC P0268
Cylinder 3 Injector Control Circuit High Voltage
DTC P0270
Cylinder 4 Injector Control Circuit Low Voltage
DTC P0271
Cylinder 4 Injector Control Circuit High Voltage
DTC P0273
Cylinder 5 Injector Control Circuit Low Voltage
DTC P0274
Cylinder 5 Injector Control Circuit High Voltage
DTC P0276
Cylinder 6 Injector Control Circuit Low Voltage
DTC P0277
Cylinder 6 Injector Control Circuit High Voltage
DTC P0279
Cylinder 7 Injector Control Circuit Low Voltage
DTC P0280
Cylinder 7 Injector Control Circuit High Voltage
DTC P0282
Cylinder 8 Injector Control Circuit Low Voltage
DTC P0283
Cylinder 8 Injector Control Circuit High Voltage
