Nick1994
$100 site donor 2024
How hard is it to get to the thermostat? It might be easy, throw in a $4.71 thermostat from RockAuto and change the oil with the $1.62 oil filter they have and drive it until it dies.
I actually looked at it again today and wouldn't be too bad, a little double jointed reach for the bottom nut but I've done worse. I could pull the alternator to get room the way im supposed to but where's the fun in that? Gonna need a long penetrating oil soak or those studs will snap right off, but I can start that way before I do the work. I wonder why they made em so dinky. Very un-toyota like of them.How hard is it to get to the thermostat? It might be easy, throw in a $4.71 thermostat from RockAuto and change the oil with the $1.62 oil filter they have and drive it until it dies.
agree 10000%I would do all of the necessary repairs and all of the scheduled maintenance but I would not "pro-actively" replace anything that is still working. Absolutely do an oil and filter change now and do them on schedule from here on out.
When I say "scheduled maintenance" I mean the stuff that the manufacturer says (in their service manual) that needs to be done. Not the useless BS Up-Selling crap that the Stealerships tell you that "needs to be" done.
You may think that right now there are plenty of other beater cars around and that you can get by by not caring for this one and that you'll just buyng another when this one fails. But it never seems to work ou that way. When You NEED a car, there's none available or the price is sky-high. It also cost time and money to get another car, pay the sales tax and new registration, etc etc. You're better off to keep one car running as possible than pay all of the fees to keep changing cars.
If you want the car to last, do all of the maintenance yourself and don't take it to a garage and certainly NEVER to a dealer!
FIX that thermostat and use one with the correct temperature rating and not higher or lower. Engines running under temperature can lead to fuel dilation of the oil and added engine wear and all sorts of other issues. Use Never Seize on all of the bolts particularly around the cooling system such as the water pump and thermostat housing, and all other parts that have aluminium in them. You'll thank me if you ever have to remove those bolts a second time.
I've been successful removing old rusty stabilizer bar links a couple of times, but only after repeatedly soaking them with penetrating oil over a period of several days.I actually looked at it again today and wouldn't be too bad, a little double jointed reach for the bottom nut but I've done worse. I could pull the alternator to get room the way im supposed to but where's the fun in that? Gonna need a long penetrating oil soak or those studs will snap right off, but I can start that way before I do the work. I wonder why they made em so dinky. Very un-toyota like of them.
Can do the oil without raising the vehicle so it's getting hard to justify not doing that.
I'll do the sway bars if the rust hasn't ruined that Allen keyed bolt completely. Thermostat and sway bars are definitely dependent on the rusty parts cooperating with me but I bet they'll go with a long time soaking. I've gotten real rusty bleeder screws to go for me that way so it might just work.
Is your fuel tank in danger of ripping loose and spilling gas everywhere? Fix that for sure. I hope that it is not driven on a public road, everyone elses safety matters even if you don't care about the car.and the fuel tank straps had failed.
Umm, WHUT?!As for oil, if you do short changes in any other vehicle you own and maintain, the "Mobil 2" concept could work great for you. If you drain out something like Mobil 1 or Pennzoil Platinum etc. at 5000 mile intervals, reuse that for another 5000 in the RAV4.
He said:Umm, WHUT?!
Don't treat an older vehicle any worse than you would a newer one, then it won't be a beater if you just keep up with everything, unless something that makes a squeak is a beater, or starts to rust out... yeah I guess if you can see body rust then I might call it a beater too but the maintenance strategy still doesn't change for something as inexpensive as oil.
I had a 2004 Rav4 that had a transaxle leak. I topped it off for the last 150,000 miles. They keep on ticking.Since the thread is still alive I figured I'd let yall know how the old Rav4 is doing. I changed the oil and am doing it again soon. Settled on a 1yr interval with Supertech 5w-30 (synthetic even!) and a supertech filter.
The thermostat fixed itself last fall so I had heat all winter which was real nice since I was helping out at a maple syrup farm about 7 miles down the road for some extra winter work.
Front brakes wore out and I ran it metal to metal for about a week until we finished up with planting then did new pads and rotors. Cheapest ones I could find. Front right caliper is dragging a bit so I've got a reman one for $35 coming to put on it.
415k miles and counting! Guess the old heap is worth a little bit of maintenance after all.
