Bought a 1998 Rav4 (auto, AWD, 2.0L, 105K miles) over the winter and with the weather breaking have started to do the typical new-to-me baselining. Pertinent to this post I've done plugs, wires, cleaned throttle body and idle air control valve, installed new fuel filter and run one can of Seafoam in the gas tank. The previous owner drove it as a back-up so it averaged about 1000 miles a year since 2018.
Issue: the car has a very low idle when stopped in drive. The idle seems to be slightly lower once the car has been driven awhile. I put the scan tool on it last weekend and warmed up it idles in the low 600s. My workaround has been to shift to N at stop light and the idle increases slightly - enough to avoid the low frequency vibration that shows up around 650 RPMs.
Besides the idle issue, It has also hiccupped under acceleration a few times and actually stalled under load on the highway last weekend. It immediately restarted. Fuel mileage is about 25 MPG commuting, so no complaints there. I have yet to see a check engine light.
Everything I am reading suggests these possibilities for essentially the same symptom: tired fuel pump, throttle position sensor, crank sensor, MAP sensor. I'm also wondering about aged vacuum lines.
Any suggestions on what to focus on next? Thanks a lot.
