M1 0W40 in both BMW 330i and Volvo S60 2.5T?
I was of the understanding that green wasn't available any more.
Maybe I'll do a UOA with the BMW 5w-30 that's in there now, and again with M1 0w-40.
Originally Posted By: nathancarter
Originally Posted By: KLowD9x
Holy [censored]! You have been going 7500 miles between services with conventional in the sump!?
Yes; that's what the Volvo manual recommends.
The Volvo manual also recommends 5w-30 conventional, except for "Extreme engine operation" for which it recommends 10w-30 synthetic.
And the BMW manual recommends 15,000 mile intervals on BMW 5w-30 synthetic, which apparently performs similarly to GC 5w-30 and M1 0w-40. (I do 7500 mile OCI)
And they both say that the transmission & differential fluids are "lifetime fill." (I've already changed 'em in both)
So, what do I believe?
People say "Use 5w-30 because that's what the manual recommends" then in the next breath say "The manual says 7500 miles? Don't believe everything you read!"
It smelled pretty burnt at the last change, but can you really tell anything by the smell coming out of the drain hole? I thought nothing of it, but for 12 years I drove an old diesel M-B 240D, so maybe the nose doesn't knows.
sigh.
This leads back to the question:
Fuel economy and turbo response notwithstanding, would M1 0w-30 really offer better protection than M1 0w-40?
The BMW, at 101k, is well out of warranty, but the Volvo still has CPO warranty to 100k... if I can find a legitimate dealer to do the CPO work, but that's a different rant.
I think the 0w40 would offer greater protection. IIRC, doesn't it have higher levels of ZDDP?
But, don't listen to the manual when it comes to servicing. I have been working on these cars for a long time and I can honestly tell you that conventional in a Volvo for 7500 miles is a very bad idea. Same for the "lifetime" ATF and "lifetime" coolant.
Put 0w40 in it and call it a day. You have nothing to worry about because I have put some SERIOUS mileage on my 850 (same engine, just higher compression and hydraulic lifters instead of the solid ones you have) with M1 0w40 and it runs like new!
That is correct, GC is now of the 'gold' variety. Some of us still have 'green' GC in our oil stashes, however.
I've got a M1 0w-40 UOA coming in the next month or two. Then you'll be able to see a BMW 5w-30 against 2 GC Greens against a M1 0w-40.
Keep your eyes peeled
Originally Posted By: jesbo
M-1 0w40 is the "European Formula" which meets ACEA A3 and BMW LL-01 requirements for extended drain intervals (Since BMW says OCI of 15K miles).
Holy Cow....15k OCI's....and I have been worrying about an oil making to a 10k OCI in our VW Rabbit.
Should it bother any of us if M1 0W40 shears down to a 30wt have way through the OCI? Does this oil have the ability to go 15k miles?
Different cars. BMW's OCI also seems to anticipate high quality (read: expensive and not always available) gas, a PCV system in perfect working order, and mostly highway driving...
Well... sort of.
For one thing, this shearing thing may be old and obsolete news. I'm not even sure if it's true any more.
To the best of my recollection, though, it always performed well even when it did shear to a 30 weight.
It certainly can go 15,000 miles in the right car under the right conditions. If you want to see whether it can do that for you, run it yourself and do a UOA. :)
Just FYI: Mobil 1 0W-40 still usually shears to 30 weight range based on UOAs. It's hard not too with 0W-40 oils, plus M1 0W-40 meets some specs (like MB 229.5) that have fuel economy requirements, so the shearing helps achieve that.
15K mile OCIs, in any engine with any oil, should be done only if UOA shows it's ok, IMO.
Thanks for the clarification, and good points about the viscosity spread and MB 229.5.
Nathan remember CAFE affects oil viscosity recommendations in the U.S. Nowhere else has it. If your 2.5T is a turbo engine I have always used a PAO or ester lube for the turbo bearings, dino I certainly wouldn't.
