This report is from my 07 Nissan Frontier VQ40 motor. This report is from the 5k run between 75k and 80k. It was analyzed thru WIX.
This was a mixture of 2qts M1 0w40, 3qts M1 5w30EP and 0.5qts M1 5w30 T/SUV. There were no top-offs during this run (or any previously). Filter used was a P1.
Code:
OIL 2qt M1 0w40, 3qt M1 5w30EP, 0.5qt M1 5w30 T/SUV
MILES IN USE 5.0k
MILES 80k
SAMPLE TAKEN 16-OCT-12
SAMPLE TESTED 06-DEC-12
ALUMINUM 8
CHROMIUM
IRON 11
COPPER 3
LEAD 3
TIN
MOLYBDENUM 97
NICKEL
MANGANESE N/A
SILVER
TITANIUM
POTASSIUM
BORON 88
SILICON 23
SODIUM 2
CALCIUM 2361
MAGNESIUM 256
PHOSPHORUS 828
ZINC 938
BARIUM
Coolant No
INSOLUBLES N/A
WATER
FLASHPOINT ºF N/A
SUS VIS 210ºF N/A
cSt @ 212ºF 11.4
TBN 5.6
Diagnosis per WIX:
All wear levels appear within acceptable limits for first sample. Silicon level (dirt/sealant material) satisfactory. Water content acceptable. Customer note: 2qts 0w40, 3qts 5w30EP, 1/2qt 5w30 T/SUV. Based on mix of oil grades, Viscosity appears within acceptable range.
This is my first UOA on motor oil so I was looking for the groups opinions. I know the silicon is high and I need to clean my CAI filter and add a pre-filter. With the TBN being at 5.6 after 5k, does it seem reasonable to simply do a filter change at 5k and top off with 0w40 (to keep the TBN and vis high) and run it another 5k for a 10k total run? Unsure if I should re-sample at 7.5k total to see if 10k is good or if I should run it to 10k without the stop at 7.5k.
-Michael
Code:
MILES IN USE 5.0k
MILES 80k
ALUMINUM 8
CHROMIUM
IRON 11
COPPER 3
LEAD 3
TIN
MOLYBDENUM 97
NICKEL
MANGANESE N/A
SILVER
TITANIUM
POTASSIUM
BORON 88
SILICON 23
SODIUM 2
CALCIUM 2361
MAGNESIUM 256
PHOSPHORUS 828
ZINC 938
BARIUM
Coolant No
INSOLUBLES N/A
WATER
FLASHPOINT ºF N/A
SUS VIS 210ºF N/A
cSt @ 212ºF 11.4
TBN 5.6
Diagnosis per WIX:
-Michael
