Nothing major here other than fuel, which I don't think is an issue. Sample was taken when engine was hot. I think i will stick with 7k-7.5k intervals. Mostly posting for other member reference.
Link to previous UOA: HERE
Code
Comment: This turned out to be another great report for your BMW. Our only complaint is the mild fuel
dilution. The key word there is "mild" because it's only a trace of fuel -- this amount is usually from sampling
without the engine being fully warm. It's all good news otherwise, as the viscosity was still a 0w40 and
wear metals are in excellent shape. If you're wondering why titanium started showing up in 2017, it's just oil
additive not new engine wear. The oil was free of harmful contamination, while the TBN was fine. A
~9,000-mile run would be a piece of cake.
MAKE/MODEL: BMW 3.0L (N55) I-6 Turbo
OIL Castrol EDGE 0w-40 Castrol EDGE 0w-40 Mobil 1 0w-40 Mobil 1 0w-40 BMW 5w30 Mobil 1 0w-40 BMW 5w30
MILES IN USE 7181 7323 6111 6000 7630 5520 5150
MILES 76898 69717 62394 56283 50284 40660 35140
SAMPLE TAKEN 9/29/2018 9/12/2017 7/9/2016 10/12/2015 3/31/2015 5/1/2014 11/16/2013
ALUMINUM 5 7 5 8 19 6 8
CHROMIUM 1 1 1 1 1 1 1
IRON 33 37 27 30 50 24 21
COPPER 5 5 3 4 6 3 3
LEAD 0 0 0 0 0 0 1
TIN 1 1 1 2 0 0 3
MOLYBDENUM 3 12 80 102 151 104 140
NICKEL 0 1 0 1 1 1 0
MANGANESE 2 1 1 2 3 1 1
SILVER 0 0 0 1 0 0 0
TITANIUM 45 40 0 0 0 0 0
POTASSIUM 7 7 6 16 14 2 2
BORON 35 34 135 136 75 151 61
SILICON 4 5 4 4 6 4 3
SODIUM 5 6 5 7 9 3 6
CALCIUM 2154 1885 2865 3068 2397 3239 2321
MAGNESIUM 84 396 19 21 18 19 17
PHOSPHORUS 839 857 901 898 935 989 850
ZINC 977 996 1054 1150 1112 1176 976
BARIUM 0 0 0 0 0 0 0
SUS VIS 210F 65.0 69.2 70.2 63.2 68.5 64.4
cSt @ 100CF 11.61 12.59 12.75 13.01 11.12 12.56 11.44
FLASHPOINT F 385 410 400 390 395 415 420
Fuel TR
Antifreeze 0.0 0.0 0 ? 0 0 0
WATER 0.0 0.0 0 0 0 0 0
INSOLUBLES 0.2 0.3 0.2 0.2 0.3 0.2 0.4
TBN 2.8 3.8 4.2 5.6 3.7 5.6 5.3
Code
LEAD 0 0 0 0 0 0 1
TIN 1 1 1 2 0 0 3
Fuel TR
