Latest UOA from my 2003 BMW 330Ci M54.
An Actual winter this time since I moved back to Indiana in Jan 2010. Earlier UOAs are from Houston, Tx. Fewer short trip now so the TBN seemed to hold up better.
I installed the BMW Performance intake (paper filter) last fall and had Dinan Stage 2 software installed in Feb of this year.
I refilled with 6 quarts of Red Line 5w-30 plus an older quart of Red Line 5w-40 that should still have the high moly.
I figure the 100C viscosity should be around 11.2-11.2 for the mix.
Code:
Miles on oil 5011 5000 4300 5958 4514 5347 5017 3839 7,250 5,100 7786 7400 5643 8119
Total miles 21130 26100 31407 37365 41879 47226 52245 56084 63,334 68,400 71120 78494 84137 92256
Date 05/05 10/05 3/06 6/06 3/07 6/07 3/08 9/08 10/08 6/09 6/09 12/09 8/10 4/12/11
Make up oil 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.5 0.0 0.0 0.0
Oil Brand BMW Castrol Castrol BMW Castrol CastrolCastrolCastrol RL RL RL RL RL Red Line
Weight 5w-30 0w-30 0w-30 5w-30 0w-30 0w-30 0w-30 0w-30 5w-40 5w-40 5w-40 5w-40 5w-40 5w-40
Filter BMW Mann BMW BMW Mann Mann Mann Mann Mann Mann Mann Mann Mann Mann
ALUMINUM 4 2 2 2 2 2 4 2 2 4 2 3 3 5
CHROMIUM 1 0 0 0 0 0 0 0 0 0 0 0 0 0
IRON 9 7 6 4 8 6 11 9 7 7 9 8 7 10
COPPER 28 22 15 18 22 8 15 9 5 17 21 15 17 19
LEAD 2 2 2 1 1 1 1 0 0 0 1 4 1 1
TIN 0 1 0 0 1 1 0 0 0 0 1 0 0 2
MOLYBDENUM 124 19 4 104 16 4 3 2 3 149 207 33 14 9
NICKEL 1 0 0 0 0 0 0 0 0 0 1 1 1 1
MANGANESE 3 1 1 1 1 1 2 1 1 1 3 2 1 1
SILVER 0 0 0 0 0 0 0 0 0 0 0 0 0 0
TITANIUM 0 0 0 0 0 0 0 0 0 0 0 0 0 0
POTASSIUM 9 1 6 1 2 0 8 3 2 3 5 2 4 5
BORON 38 9 3 21 4 2 3 2 1 4 5 2 3 3
SILICON 5 3 3 3 3 2 4 3 4 6 7 5 4 4
SODIUM 2 4 3 5 3 3 4 2 3 9 12 7 5 13
CALCIUM 3446 2125 1704 2463 2702 2985 1864 1891 2452 2142 2574 2530 2677 2388
MAGNESIUM 18 311 455 83 129 147 448 551 86 30 36 17 16 14
PHOSPHORUS 853 748 781 662 737 782 872 885 988 1032 1134 1076 1182 985
ZINC 1050 889 964 847 878 1001 1115 1087 1282 1228 1446 1345 1363 1056
BARIUM 0 0 0 0 0 0 0 0 0 0 0 0 0 0
SUS @ 210F 65.6 62.5 63.2 64.1 63.8 65.8 64.2 65.5 73.9 78.2 78.4 77.6 75.7 78.6
cSt @ 100C 11.76 10.91 11.11 11.35 11.27 11.82 11.38 11.75 13.97 15.08 15.11 14.92 14.43 15.16
Flashpoint F 375 375 325 415 360 395 380 400 440 385 410 420 410 390
Fuel %
Antifreeze % 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0 0 0 0
Water % 0.0 0.0 tr 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0 0 0 0
Insolubles % 0.3 0.3 0.2 0.3 0.2 0.2 0.2 0.3 0.3 0.3 0.3 0.3 0.3 0.3
TBN 1.8 4.0 4.7 3.2 2.9 2.6 2.9 4.9 4.0 1.7 1.3 2.7 3.2 2.5
Blackstone Comments:
Note copper. It's still lingering a little higher than average, but all other metals are reading normally, and
some are reading better than average despite your longer oil run. As we mentioned last time, maybe this level of
copper (give or take a few ppm) is going to be normal for your engine at this stage in its life. We should also note that
since you ran this oil longer than the last, copper is actually better on a per-mile basis. The trace of fuel is not a
problem. The viscosity was a little higher than average. The TBN read 2.5, still good.
Code:
Fuel %
