2017 Corvette / Mobil 1 ESP 0w40 / 5.2k mi
Frisco, TX
This is the second full interval with the new Mobil 1 ESP Formula 0w40 with about the same mileage and duration, but less track time (5 hours this OCI versus 10 on previous OCI). The OLM read 30% when the oil was changed out. Some of these track outings were in ambient temps of 90-100 F, and the PDR data indicated oil temps as high as 275 F.
Blackstone said things look good and the motor is handling the hard driving fine. They did highlight that the viscosity was a bit out of grade for a 40 but said the same thing last time.
I'm still undecided if I will continue with this oil after this OCI. Chevy recommends 15w50 for track use, and there are a number of stout 0w40s out there like 300V, RL, or RLI that can be had for roughly the same price. This was a slightly shorter run that did improve TBN, wear metals, and viscosity, but TAN still rose due to the increased short tripping. Discuss.
Obligatory COTA shots below...including one at night.
Code
OIL Mobil 1 ESP 0w40 Mobil 1 ESP 0w40 Mobil 1 5w30 Mobil 1 5w30 Mobil 1 5w30
MILES IN USE 5,230 5,915 3,848 5,651 741
MILES 21,385 16,155 10,240 6,392 741
SAMPLE TAKEN 9/13/19 2/26/19 6/22/18 9/22/17 4/12/17
ALUMINUM 5 6 6 10 3
CHROMIUM 1 1 1 2 1
IRON 18 35 34 53 48
COPPER 3 3 5 13 28
LEAD 2 1 1 1 1
TIN 0 0 0 0 0
MOLYBDENUM 66 69 80 76 84
NICKEL 0 0 0 0 0
MANGANESE 0 0 1 2 2
SILVER 0 0 0 0 0
TITANIUM 0 0 0 0 0
POTASSIUM 2 1 2 5 10
BORON 175 156 66 54 106
SILICON 7 10 12 40 74
SODIUM 4 7 4 5 7
CALCIUM 1441 1539 1103 956 1043
MAGNESIUM 30 119 779 682 624
PHOSPHORUS 719 769 735 627 692
ZINC 798 801 819 733 753
BARIUM 0 0 0 0 0
INSOLUBLES 0.1 0.1 0.1 0.1 -
WATER 0 0 0 0 0
FLASHPOINT �F 410 390 395 390 SHORT
SUS VIS 210�F 64.4 62.5 56.8 54.8 -
cSt @ 212�F 11.44 10.92 9.29 8.71 SHORT
TBN 3.6 2.8 4.4 4.6 6.2
TAN 4.6 3.7 2.8 4.7 1.9
You are pushing the Vette hard and she is looking pretty good if not great. It is nice to see you enjoying the Vette.
Originally Posted by dparm
This is the second full interval with the new Mobil 1 ESP Formula 0w40 ...
I'm still undecided if I will continue with this oil after this OCI. Chevy recommends 15w50 for track use ...
Mobil 1 ESP 0w40 is a thin 40 grade to start with, at 12.9 cSt hot when new. The oil at the end of the OCI, being 11.44 cSt hot, did thin out, but not by very much. Given the usage, that seems decent. And the used oil analysis shows iron trending down nicely.
However, you, being in Texas, and tracking the car, and seeing peak oil temps of 275*f, might want to consider something thicker. When I raced, Mobil 1 15w50 Red Cap was the go to oil.
Nice Vette. I find it strange how GM calls for 0W20 in most of their other mass produced V8's, but calls for a heavy weight oil in the Vette. Seriously makes me wonder if I should at least up my oil to a 5W30 instead of the 0W20.
Nice car!! As already mentioned I think the oil did fine, especially considering how the car was used. I know this is Bitog, but I'm not sure if I would be hunting for the perfect oil, you may already have it.
Hey nice Vette op! Look at those rotors glowing red! Looks like Mobil 0w40 is a pretty Stout oil. Is it a Zo6 or Grand sport?
I would almost bet the reason for heavier weight oil is because of much less airflow thru the front end. I would think if you put a truck sized radiator and coolers on a Corvette along with a truck sized grill you could get away with much thinner oil. But I'm no engineer....
Originally Posted by joekingcorvette
Nice Corvette. I cannot tell if it's a Z-06 or a Grand Sport? Yes, you do have those rotors hot.
Yep, Grand Sport.
Originally Posted by Quattro Pete
Do you have a RAW file for this one? This would help boost exposure on it.
I don't. These were part of a photo package I bought, but I did get the full-res JPGs.
Wear numbers look good, but if you want to lift the viscosity a little just add 2 or 3 qt's of Mobil 1 0w50 racing oil. Big shot of moly with a higher dose of ZDDP, calcium, Boron. Even has a TBN of 8
Rod
No you shouldn’t on a steeet vehicle. The reason for 0/20 as far as I’ve been told
Is to keep from sludging up the small oil passages in today’s modem engines.
