I really hate those landau roofs. SO MANY Panthers ended up with them. I passed on a few cars because of the awkward roof treatment.
What are you meaning by MPG e number?That really wasn’t what it was about, the model name, it was about the high 133 mpg e number. As for moving on from the Prius that could be a new topic in “vehicles.”
Not sure if anyone has a higher mpge number, I remember maybe 134. Leave it to Toyota to post a high efficiency number based on engineering if they want to.
Some good info here if you can stomach Cammisa. The lead engineer for the Tesla Model S is Lucid's CEO and CTO.
See post #29. Ask that guy. You mean you find fault with a space between letters? You do see I also wrote mpge as well? I mean, really?What are you meaning by MPG e number?
Have not heard anyone get excited about a Prius in a long time.
The Prius has been an incredible success for Toyota. And no one does hybrids like Toyota.I think people have largely moved on from a Prius.
Another member here did a fine job of explaining how that ship may have sailed, other cars offering similar utility.
I'll simplify it for you, I do not know what "eMPG" or whatever you are saying is and would like you to clarify, if you know.See post #29. Ask that guy. You mean you find fault with a space between letters? You do see I also wrote mpge as well? I mean, really?
The Prius popularity is another topic. But they are very popular, maybe the hearing needs amplifying?
I am aware of this, they are made at a different plant.. we make Hybrids and ICE presently, they are dominating in sales. (Well, at least one is. No Priuses, that's either Japan or Kentucky maybe. I do not know, exactly.) New vehicle will likely be an all-electric and be two models side-by-side, interesting to see if 100% electric or if they go a hybrid route.. I'm with you.The Prius has been an incredible success for Toyota. And no one does hybrids like Toyota.
Toyota’s Prius was the leader of the hybrids for a long time until other automakers started offering competitive products with more conventional styling. Getty Images
Again, see Post #29. It’s not what do I mean by mpge, it isn’t my term.I'll simplify it for you, I do not know what "eMPG" or whatever you are saying is and would like you to clarify, if you know.
If you don't know, that's okay, just say so.
4 guys hanging out at the corner can get together and in a couple of hours create a better interior than Tesla's.I like the interior much better than Tesla’s. The range is impressive. The HP in the upper models is impressive as well.
https://www.caranddriver.com/lucid-motors/air
Thank you, @JeffKerykMPGe stands for "miles per gallon equivalent". It is the EPA's method of rating EV mileage. I would say it can be used for EV efficiency comparison.
More from Kelly Blue Book:
"When the EPA devised MPGe in the early 2000s, the government agency calculated that 33.7 kilowatt-hours (kWh) of electricity is comparable to a gallon of fuel in terms of its energy content.
True, pulling 33.7 kWh of electricity from the grid in a place dependent on coal power is not quite the same as using wind power. But such an average makes for a more reasonable comparison applicable to drivers.
For example, a car that uses 33.7 kWh of electricity to travel 100 miles rates 100 MPGe."
It's an attempt to correlate a legacy parlance (mpg) to something understandable for "average Joe" with the shift to EV's, and it's as awkward as it sounds. It's the same with the charging in "Mph" which is also just as goofy.Thank you, @JeffKeryk
Makes sense.It's an attempt to correlate a legacy parlance (mpg) to something understandable for "average Joe" with the shift to EV's, and it's as awkward as it sounds. It's the same with the charging in "Mph" which is also just as goofy.
It's super easy to learn the proper units. In the case of EV's, this is all relative to the kWh, so:
- Efficiency is miles per kWh. This is just like Mpg, but batteries hold kWh, not gallons. The more miles per kWh you can go, the more efficient the vehicle
- Capacity is measured in kWh. Your battery holds x number of kWh rather than gallons. Bigger batteries, like bigger fuel tanks, will take more kWh to fill, and thus cost more. This, like your gas tank size, when coupled with your efficiency, dictates your range.
So, when you charge an EV, you are buying kWh to put in the battery, just like you'd be buying gasoline to put in the tank.
Sure, if you have to press the "go pedal" more to keep the same speed going up a hill, then an EV will suck more juice just like an ICE will.Is the m/kWh drop going uphill in an EV similar to or more or less than the drop in mpg you see with ICE? Without getting all worried about fine details, say if your F150 is running at 18 mpg (instantaneous) at the base of the climb and 9 mpg while on the climb would a Lightning showing 50 m/kWh show 25 on the climb? I guess maybe what I'm asking is an EV drivetrain more efficient than an ICE?
Forgive me , I'm still trying to understand where the electricity goes when it hits the end of the wire.![]()
Some similarites for sure; fuel consumption is based on load. There is a difference on low load, such as extended downhill. Of cource an ICE vehicle uses less fuel. Similarly, but different, an EV can actually regain fuel via "regenerative braking". From a high level, regenerative braking uses some of the kinetic energy of the vehicle to recharge the battery or even used immeadiately, where braking in an ICE vehicle converts the kinetic energy to heat which returns to the atmosphere.Is the m/kWh drop going uphill in an EV similar to or more or less than the drop in mpg you see with ICE? Without getting all worried about fine details, say if your F150 is running at 18 mpg (instantaneous) at the base of the climb and 9 mpg while on the climb would a Lightning showing 50 m/kWh show 25 on the climb? I guess maybe what I'm asking is an EV drivetrain more efficient than an ICE?
Of course. Is one more efficient than the other is the question.
Forget regen braking. See above, does an EV use it's available power more efficiently than an ICE? Don't know how to phrase it. Are EVs more efficient with their available energy because of less mechanical losses, less heat loss from combustion etc?
Yes, EVs are more efficient in turning electrical power into motion than ICE is turning gasoline into motion. Most of the energy in gasoline is turned into heat, not motion.
