I wonder if this stuff works like VSOT? There you never have to add it again if you're using the right oil. 150ppm of stead drip from the slug it forms in your oil pan..
Oh ..and I had to use snake oil to get it out. Several oil changes didn't seem to eliminate the moly leachate from showing itself.
I'm missing the point of why the "snake oil" to get it out? Moly is a good thing that you'd want in the engine, did it cause a problem? VSOT was a good product. Eventually it would have been used up or removed after a few or several oil changes. IMO is if you used an oil that contained no moly eventually the moly would have been gone.
The point was the stuff sank out like Pb balloons in my engine oil pan and filter. It remained inert until I used Bruce's oil with NO MOLY in it. used oil analysis were filled with all kinds of other stuff that it grabbed on the way out of suspension.
There's no way anyone would "engineer" an additive with a heel process of leaching into the sump. Suppose I had added one bottle per OCI as recommended on the bottle and never cut open a filter? Eventually I'd never be able to fit 4 quarts in the pan without over filling it by 25% or more.
What you may be missing, Frank, is that the image is before I even had Bruce's oil in there. That was after a RTS run. I had to use the "snake oil" in between Bruce's oil use since we kept wonder where the moly and silicon kept coming from. After the "snake oil" treatment, the moly ..and most of the other readings calmed down to sensible levels.
Just be careful on how much of this stuff (any high potency additive) you put in at one time. Double your moly ..triple it ..but don't dose the heck out of it thinking you're duplicating Honda's double secret probation pre-Imperial-pre-feudal monk assembly process.
Gary I was not disagreeing with anything you said, just asking a question, and following your humor in using the term "snake oil" for clean up. All good fun.
I am testing Lubro-Moly in a HM beater, and have mentioned my observations in another post up above. I see what is going on in the pictures, and perhaps the viscosity of the VSOT had a lot to do with the problems you had with the moly. I'm not trying to stick up for Lubro-Moly please understand that. I remember many, many years ago when STP was the craze. I had a friend who used it without fail every OCI. He had a coat of slimy muck in the bottom of his oil pan that was unreal. Maybe that is what happened inside your filters and in your oil pan. Maybe the moly that was trapped in that slime from the thick VSOT was slowly mixing into the fresh thin oil, causing the leaching even after you stopped using it? Lubro moly seems to pour just like any 5W30 oil, and maybe it gets distributed better as a result.
I do agree that adding the Lubro-moly every OCI would be a mistake, and the company recommends against it.
Did you notice any change in viscosity in UOA in the oil once you stopped with the VSOT? I'm thinking the base they mixed VSOT with was just not a good base for the moly, just too thick in plain English. They no longer make the product, so maybe that is a good thing?
I'm just sharing ideas here, glad you are sharing yours.
