Originally Posted By: FMC
Normal daily driving, 50/50 highway/city, east coast temp ranges 10 to 100 degrees
The limiting factor on how light an oil you can run is the minimum oil pressure that's specified for your engine. Your engine has no idea of the grade or viscosity spec's of the oil you're running, all it knows at any give time is what the operational viscosity is and the best proxy for that is the engine's oil pressure. So to determine that you need to install an accurate OP gauge.
The lightest SM/SN oils you can buy are the Japanese OEM 0W-20's such as the Toyota Brand OW-20 and Honda Brand 0W-20.
Even these oils will be thicker than optimum in every engine until the oil temp's get up to at least 75C-80C. If your oil temp's get higher than that, that's where the OP gauge will tell you if your OP is getting too low as the oil continues to thin with higher oil temp's.
