Originally Posted By: jldcol
You can treat syn oil as 1 weight lower, here 10w syn~5w dino. That's group 3 syn, real syn probably 2 weights lower~0w, which doesn't exist as a dino yet. There are 6 winter weights, 25 20 15 10 5 and zero. I would say there are 3 winter climes mild~30-50 degrees, Hawaii? cold zero-32 degrees and frigid below zero. 25 and 20 ok in the mild winters, 10 and 15 ok in cold winters, and 5 and zero wt. in frigid cold winters. All these are for dino oils, syn's 1 catagory colder ok, so 10w syn, I would think ok to below zero, perhaps -10 degrees.Amsoil seems full syn stuff so maybe even a bit lower.
That is utter non sense. Look at the data sheets. Synthetic 10w30 like Amsoil ATM is not going to pass the 0w SAE cold cranking test. It might pass the SAE mini rotary viscometer for 5w.
By definition 10w is safe to -13F.
I'd say a synthetic 10w30 with a CCS below 4,000 cP :MIGHT: get the job done in the SAE 5w CCS test (-22F), so I'd say a safe limit for 10w30 synthetic would be between -13F and -22F.
Not a snowballs chance in [censored] it would suffice in conditions needing an actual 0w oil.
