They say some ungodly percentage of a car's wear comes from driving while the engine is cool.
The coolant heats up pretty quickly, but the oil is said to take much longer, and the thicker cool oil doesn't pump as well, causing limited protection against engine wear until the oil can heat up.
My car specifies something like 10W-30 oil. I am running 5W-30 PurePlus. Is it a good or bad idea to run a lower Winter viscosity? Could it help reduce the wear caused by a cold engine?
