Originally Posted by OVERKILL
Originally Posted by StevieC
I didn't write it, they did. And after seeing the numbers on my used oil analysis in the Journey and Santa Fe I think they know what they are talking about.
I'm aware you didn't write it, I simply pulled the quote from your post.
No need to get defensive, however that statement is false. If you go back and look up the main bearing clearances for engines over the years, they really haven't changed much.
Ignoring for the moment that used oil analysis aren't a tear-down with measurements so we avoid that detour for the time being, architectural changes have been made to engines to accommodate the use of thinner lubricants. These changes are myriad, but a few of the major ones are:
- Deep skirted rigid blocks
- Multi-bolt (often pinned) main caps
- High volume crank-driven oil pumps
Rigidity of the structure housing the rotating assembly is a key thing here. You eliminate the ability for things to flex, distort and move around you can get away with having less oil between the surfaces.
Now, with the push to even thinner oils, what Honda has been doing is increasing bearing width, which is necessary with a thinner film for things to survive. There's a thread about it on here somewhere, it's quite interesting. As the film gets thinner and thinner and more components are operating in mixed and boundary, the additive package must work to minimize the wear occurring in this realm. It's about wear control, since it cannot be eliminated. The moment surfaces touch, there is wear. Now, this introduces friction, as does increasing bearing width, so it was an interesting discussion that I recall Shannow being engaged in as to the frictional tradeoff by increased operation in this end of the Streibech curve vs the increased friction of a heavier lubricant in hydrodynamic. Apparently, boundary and mixed still wins, even with the larger bearings. If it didn't, Honda wouldn't be pursuing it.
It is hard enough to get people to understand why engine wear is greater when the engine is warming up as compared to when the engine is operating at its stabilized operating temps.
