Hi,
I have a Husqvarna YTH 24V48 riding lawn mower with: Mulching kit, 48 Inch deck and 24 Horse Power Brigs and Stratton engine (724 cc).
The recommended engine oil is genuine Briggs & Stratton SAE 30 Premium 4-Cycle small engine oil with API SG-SL rating.
The mower is 5 years old. It's possible the owner's manual excluded API SM or higher due to reduced phosphorous content.
The recommended high efficiency oil filter is a genuine Briggs & Stratton 696854.
The Briggs and Stratton oil is expensive with a high unit price per quart
even if you buy in the 1.5 quart jugs, and its just SAE 30 API SG-SL conventional oil.
The oil filter is expensive also.
I would prefer to stock up and buy bigger container of oil and use for the next 3+ years (as I change the oil/filter at the begging of every mowing season (End of April of each year).
I wanted to find a low price (but just as good) alternative for the Briggs & Stratton oil / filter.
The only decent choice I could find for the oil was:
Walmart Super Tech Conventional SAE HD 30 Motor Oil, 1 Gallon Bottle for $13.97 (3.49 a quart) which is good, but it's not synthetic oil,
and it doesn't have the API SG-SL rating. Instead it has this diesel engine rating: Heavy Duty Diesel Oil: CF-2.
Would CF-2 rating mean it has plenty of detergents and phosphorus?
https://www.walmart.com/ip/Super-Te...or-Oil-1-Gallon-Bottle/859463519?from=/search
I'd prefer to keep the same viscosity oil, but just to receive some recommendations on low priced but compatible oil/filter brand(s)
and a low priced store to buy them from.
Any and all suggestions are welcome of other brands / other stores for both the SAE 30 oil and the lawn tractor filter.
Also, is there any SAE-30 Synthetic oil in 5 quart or gallon jugs from any store at low unit prices per quart?
