- Joined
- Apr 28, 2025
- Messages
- 13
so I've read and done some Research as I wanted to Run a Longer Oil Filter - seeing a Oil Cooler Kit which is real Basic for
Kohler 7000 series Motor 24Hp to 26Hp Range seems - Like - I would be Buying an Oil Cooler set up for Freaking Honda Type R or
Blown Mustang 5.0 with 8500 RPM Motor . . $$$$$ Nuts ..
OK so I Look at PH3600 and it stated used on many Riding Lawn Mower Motors - it's - Price isn't Crazy & It Gives Extra Oil Capacity
Plus Extra Metal Hanging out in Wind . . ( May Help Keep Temps in Check . . )
Issue is everything I've Read on this Site seems to Never Answer all Questions . .
1. Oil Flow per Min. ( Quarts or Gallons )
2. 20 Microns , so Not to Fine as in 18 Microns or Lower - to cause large Drop in Pressure . .
3. By Pass Valve 12 psi , so many Talk about By-Pass Valve - but Give Wrong Impression . . as ( It's Difference ) Not when Reaching a Certain PSI . .
4. Most Modern Riding Mower Engines - have what - Oil Pressure all I Find is 25 psi to 50 Psi - which might vary some 10W-30 vs straight 30w
Examples of Actual Oil Pressure - Not Found . . with Oil Weights when Warmed & Running . .
5. Maybe I didn't Look Hard Enough ~ Kohler ~ Oil Filter Spec's ( didn't Find those ) . .
6. Oil Pressure Drop on Normal Lawn More Filters 6-10lbs ( ? ) Warmed Up
7. Oil Pressure Drop on Fine Filtering - like 18 Microns of Lower 8-12 Psi ? Hot ?
Maybe We all could just Clear Up some Facts . . THANKS ~ DAN
