### Husqvarna Lawn Mower with B&S 160cc Engine Issues and Fixes
I have a Husqvarna lawn mower with a B&S 160cc engine. Recently, it stopped moving and then the engine quit with a puff of smoke from the air filter!
After 9 years of heavy use, I had no patience and time to fix it and bought a Honda lawn mower, which is working fine. However, when I posted in my neighborhood about giving away the old mower for free or as metal scrap, I got lots of calls saying I needed to pay them to take it off my property. Its a great engine and lawn mower that has served me well for the last 9 years actually. Its a Husqvarna LC 221A.
Intrigued, I decided to work on it. Here’s what I found and did:
- **Issues Found**:
- Idler wheels jammed due to bearing failure.
- Belts melted the plastic idler wheels due to friction.
- Blade adaptor spins freely as the key is gone.
- Carb flooded with oil and dirt.
- Flywheel pin crushed but okay.
- **Replacements Made**:
- Replaced the carb, spark plug, flywheel key, blade adaptor, wheels, cleaned air filter and replaced fresh oil. I have always taken care of the lawn mower with regular oil replacements and clean filters. But the jammed idler wheels caused a whole series of issues.
- Checked and adjusted the valves for the first time and it was within the spec of .004". Same engine with different serial numbers but same capacity have different valve clearances. Had to get the QR code on my engine to get the exact specs.
Everything is back to normal except for the engine RPM, which slowed down after replacing the carb. The replacement carb was a cheap one from Amazon; I still have the original, which I plan to clean later.
I adjusted the RPM by pressing the tab that holds the governor spring, but I’d like to know the factory RPM setting. I just got an RPM meter to check it and measure it on my Honda for reference.
If anyone knows the factory RPM for these engines, please let me know. If not, what would be the ideal factory RPM?
Another strange thing in my B&S manual is the oil spec: SAE 30 preferred, 10W-30 for varied temp zones, and 15W-50 Vanguard synthetic for ultimate performance. That’s quite a leap from SAE 30 to 50! I’ve always used Shell Rotella SAE 30, FYI.
Any insights or advice would be appreciated!
- **Issues Found**:
