Some modern computer controlled engines will see the lower coolant temperature as an engine that isn't fully warmed up yet and keep the fuel mixture extra rich. Your engine won't run as well, it'll burn a lot of gas, and it won't have clean combustion.
Stick with the original 190+° stat. Your engine runs better. If it overheats, find the real problem and fix it.
Ken
Ken
