Looking for long version of a ph2, 22x1.5mm thread oil filter.
eastern NewMexico
I've got a 2010 ford explorer 4L engine it takes a 22x1.5 thread filter. The 22x1.5mm oil filters are new to me.
There's plenty of room to run something double the length of a ph2 filter.
I use the TG2 on my old F150 5.4 never found a longer filter that would work. The TG2 has slightly more Sq. inches of media than the PH2 that is about the best I could do.
If youall want an oversized 22x1.5mm thread oil filter that fits most engines look up whatever filer brand you like for a 2014-2019 ram 3L eco diesel.
This one is around $25.
A fram synthetic endurance FE2 for $13 is probably the way to go. Assuming a vehicle is well kept Ideally I'd run a $13 FE2 and $25 PP every oci. Maybe run the FE2 for 2 oil changes.
I'll probably run the WL10058 for that first run of VRP, cut it open after 3k to 4k miles and go FE2 or wl10058 based on what's in there and more VRP.
I got a quart of oil in there and it wasn't quite all the way full.
WL10058, made in Korea.
Wix 51372, doesn't say where it's made, which is a pretty good clue as to where it was made....
This one is going to be on there for a while. Probably do 2 oci. This thing is a dumpster.
