Let's see what we can pull out of our behinds
This one even is a Ford part number (Euro)
Part Number: 51087
UPC Number: 765809510876
Principal Application: Ford European-Dorset Engs.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.477
Outer Diameter Top: 3.661
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 19
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 355
Max Flow Rate: 11-13 GPM
Nominal Micron Rating: 24
Part Number: 51592
UPC Number: 765809515925
Principal Application: Cummins, Komatsu, Onan Engines
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.214
Outer Diameter Top: 3.663
By-Pass Valve Setting-PSI: 18-20
Burst Pressure-PSI: 250
Nominal Micron Rating: 16
Gasket Diameters
Number O.D. I.D. Thk.
15614 2.834 2.462 0.255
Gasket Diameters
Attached 2.834 2.462 0.200
OEM size:
Part Number: 51372
UPC Number: 765809513723
Principal Application: Ford/Lincoln/Mercury (91-08), Mazda (00-08), Cadillac STS-V, XLR-V (06-08)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.167
Outer Diameter Top: 3.660
By-Pass Valve Setting-PSI: 16
Beta Ratio: 2/20=12/25
Burst Pressure-PSI: 275
Nominal Micron Rating: 19
Gasket Diameters
