Not sure what you're using it for or trying to show, but it's not a good idea to have wood against a block wall unless it's pressure treated. Moisture in the block will rot the wood. If you were gluing the wood to the wall, is that the excess that squeezed out? If so, you should have removed that with a putty knife if you don't like the appearance.
