If you measure 99% confidence vs 97% confidence in statistics its not 2%, its the difference in the integral between 99 and 97% which is way out into the standard deviations, and again, statistically not that much. Thats the statistical argument.I call B.S. 99 percent at 20u will have better efficiency at 5u compared to 95 at 20u. Most wear comes from the finer particles.
If you want to argue practicality, yes you might have a small percent fewer 5um particles, but anyone that builds engines will tell you a properly maintained engine isn't going to wear out from 5um particle before something else major breaks first.
Your also assuming that 99% and 97% are absolutes across every filter across every media run which is untrue. There is a acceptable tolerance, not to mention the ratings by the manufacture is based on some specific filter.
Not telling you not to run whatever filter you feel best with, but my comment that 97 vs 99% are statistically and practically are meaningless as presented by fact. Its not BS its math.
Now the difference between 20um and 30um at 99% is a different story.
