- Joined
- May 28, 2014
- Messages
- 2,515
The frame of the vehicle with the constant twist.The suspension system- shocks,struts, stabilizer bars. Think of the bigger components of your vehicle than the particles in the oil of all places that you will NEVER be able to totally get eliminated no matter how badly you want that to be! Your engine will in most cases outlast the rest of the vehicle in most cases.Just because you can't huge noticeable wear with your eyes doesn't mean it's not wearing. Been pointed out many times that the level of wear should be considered over the life of the vehicle. Ring wear is usually the main thing that happens to ICE, and dirty oil just contribute to more wear over the long run.
My goal is to use higher grade oils, air filters and oil filters to complete the trifecta required to mitigate wear from all angles and keep the engine in good physical health to keep its operation in top condition. Every parrots the "the air filter is the most important filter", which is true ... but it doesn't mean that using a low efficiency oil filter is a good idea. If debris gets past the air filter, then the oil filter is the last component that can remove that debris, so it too should be high efficiency to ensure it catches as much as possible, regardless of how the debris gets into the oil.
I bet you'd freak out knowing all of the dust,dirt and debris that you constantly consume on a daily basis in your own home. This is your health! Which is waaaaaay more important than a oil filter! Do you have an air purifier?! Great, I do too! But you know what, it's not going to capture 100% of the airborne particles in your home either.
Your obsession is crazy and has no conclusion to achieve your 100% you are so chasing!
