5 years ago is better than 20 years ago for the Chrysler early 90's era minivans
It was being worked on in a shop. Wasn't running on the road.
And Neons, and K-cars, and the 4-cyl Dusters… and probably others as well.The only Chrysler products I recall burning oil were the early 90s minivans with the Mitsubishi engine. And those have long disappeared from the roads around here. Probably has been 20 years or more since I've seen one.
So you’re agreeing that RP filters are not 99%@20u, correct?From the RoyalPurple website:
https://www.royalpurple.com/consumer/extended-life-oil-filters/
- ß25 = 100 (at 25 or greater micron, media is 99% efficient.)
- ß20 = 75 (at 20 or greater micron, media is 98.7% efficient. Also considered absolute rating.)
- ß10 = 5 (at 10 micron or greater, media is 80% efficient.)
If they were identical, Royal Purple would say they were. So would the ASTM test. 0.3% difference is 3000ppm…. Not insignificant.I round up and agree that 98.7 rounds up to 99%. The repeatability of marketing tests are vague enough and filter PN specific.
So you’re good with a manufacturer lying to you about its products specs, or with how it honestly compares to the competition?You guys are worried about 99, or wait 97.3556%. I've been working on engines and cars trucks etc,since high school auto mechanics.Not once have I had an oil related failure worrying about such ridiculous miniscule difference between oil filters is a waste of time![]()
Nope ... Royal Purple says 99% @ 25u.So you’re agreeing that RP filters are not 99%@20u, correct?
If it’s ok for oil filters to cheat & cut corners, where does it end?
Has nothing to do with research. I’m not even arguing for a specific filter. If specs are meaningless in the long run, why have them?If you can sleep better at night then by all means, research with all your hearts desire.
At least they kept mosquitoes in check during summer…
There representative specs to compare one brand to the other - as published by marketing. I can guarantee you the media changes slightly from batch to batch for every manufacture, so it could be 99.3% this week and 98.7 next week anyway. Also the ratings are for some specific filter size or format, not necessarily the one your buying.Has nothing to do with research. I’m not even arguing for a specific filter. If specs are meaningless in the long run, why have them?
Depends on the total amount of debris in that micron range, and the amount of time that liquid is circulated thru said media.99% vs 97% for the same particle size is a meaningless difference both statistically and practically in my opinion.
Great mosquito repellent distribution method.And Neons, and K-cars, and the 4-cyl Dusters… and probably others as well.
I call B.S. 99 percent at 20u will have better efficiency at 5u compared to 95 at 20u. Most wear comes from the finer particles.There representative specs to compare one brand to the other - as published by marketing. I can guarantee you the media changes slightly from batch to batch for every manufacture, so it could be 99.3% this week and 98.7 next week anyway. Also the ratings are for some specific filter size or format, not necessarily the one your buying.
So yes, 99% at 20um is different than 99% at 30um for sure.
