Lexus Vehicle Health Report - Engine Oil Quality Parameter
CA
I have a 2025 Lexus TX500h with the T24A-FTS. In the vehicle health report, there is an "engine oil quality" parameter:
I changed the oil and filter at 1000 miles so the current fill has about 1600 miles. I am curious how the vehicle is measuring engine oil quality. Does anyone know?
A dummy timer that changes with miles? A sensor that reflects light to see how dirty the oil is? I'm curious too.
There is a code for the sensor
OBD-II fault code P252D​
So it must actually use some type of sensor?
probably relates to contamination more than anything.
It should be renamed "engine oil cleanliness"
Most OLMs are a math function of engine hours / environment / load, not physical sampling. Like a slightly fancier version of "next change in 3k" sticker.
Don't know about Lexus, but I copied this from a BMW source: "The oil sensor, called “OZS” by BMW, uses the lower capacitor to measure the oil quality and the upper capacitor is used to determine the oil level. The sensor measures the dielectric value of the oil against a dielectric constant (value) to determine the contamination level of the oil."
Of little help, but this discussion mentions an oil quality reading CEL. Perhaps a general Internet search of this particular vehicle system may help:
"The OPS3 multi-parametric oil quality sensor is designed for oil condition monitoring and preventative maintenance of critical machinery. Relying on tuning fork technology, the sensor monitors multiple physical properties that enable the system to determine the quality, condition and contaminant loading of fluids such as engine oil, transmission, hydraulic and gear oils. The multi-parametric analysis capability improves fluid characterization algorithms. The OPS3 provides in-line and continuous monitoring of fluids for a wide range of OEMs and aftermarket installations, including process lines and pressurized high flow conduits (e.g., engine oil gallery)..."
https://www.te.com/en/product-CAT-FPS0010.html
possibly derived from this technical paper:
https://pmc.ncbi.nlm.nih.gov/articles/PMC10146063/
I don't think the ones that are used in passenger cars are this fancy. These are pretty expensive, probably for industrial or trucks / fleet.
I wonder how much the dielectric value for new lubricants varies. Does the system which monitors this sensor become inaccurate if one were to deviate from the manufacturer’s recommendation?
The BMW spiel suggests a reference against a standard to as the trigger.
What can these dielectrics sensors actually monitor - is it a conductivity test? Does that mean PH and/or metallic solids, perhaps?
Would be interesting to see if this changes, that if resetting the OLM changes it at all; ie, does resetting the OLM (which has historically been a mileage counter for Toyota) also reset this "Oil quality" parameter, or is it actually sensor derived like BMW has been doing for ages?
It probably uses a sensor similar to what BMW and others have been using for over a decade. It calculates a dielectric value of the oil and compares it to reference value.
