Lexus TPMS help
Los Gatos, CA
Checked with Costco today, they do not have TPMS sensors for our 2013 Lexus GS350 F Sport. Bummer, as they only charge $46....
I checked with Stevens Creek Lesus, a major parts supplier. $76 each.
RockAuto wants $40 plus shipping for Denso sensors.
Any advice? Appreciate your help, as always.
Get 'em on eBay, 4 for $25 for "Pacific" units which match the Denso/Lexus ones, presumably through OE manufacture.
I've been told here they're counterfeit because they have grey valve caps. Whatever, they last as long as the originals and have the same fit and finish.
They will need scan tool programming, possibly via "Ebay Techstream" or "Carista."
Your existing sensors will have a "low battery" flag the scan tool can pick up; if you're on your originals you should just do all four.
Time to trade. What's a poor boy to do?
What's your offer? Full disclosure, she needs new TPMS sensors... Atomic Silver, red leather, 112K on the clock. Mobil 1 @ 4500 mile services. All services done, inc transmission service, filter and flush. Car is perfect. Sucks the gas,
If @The_Jeff says they last just as long as the original equipment, I'd get the ones he's recommending @JeffKeryk. The ones on our 2010 RX are still original. (y)
If a counterfeit sensor works correctly with the application, it will likely last 6-10 years as the lifespan is dictated by the coin size battery, not failure of the circuit board. In my experience, there is little difference in longevity between brands of coin cells used in watches, key fobs, etc. If you are industrious, the depleted battery can be replaced in the OEM sensor, but the juice is not worth the squeeze to me.
The batteries in my TPMS must be of very good quality; 17 years!
Another factor is how much you drive because the sensor circuit goes dormant after ~15 minutes of inactive wheel movement, thus conserving the battery. In theory, an infrequently driven vehicle's TPMS battery can live much longer than 10 years. Two of the original (Pacific) sensors on my 2005 Nissan Frontier are still functioning, but the batteries are showing weak with my AUTEL MaxiTPMS scanner.
My daughter in laws '21 Tucson has rubber valve stems with sensors from factory. I believe at least one of my daughters on her CRV was replaced with a rubber one also.
Any reason not to use them except appearance? If all 4 getting replaced anyway will look the same.
The difference is merely cosmetic. I had WalMart replace the OEM metal stem TPMS sensors in my parents' 2010 Hyundai Elantra with the rubber stem Bartec sensors last month. They work fine.
Depending what winter tires I get where, they might be what I do for the winter rims for the Tucson. We just picked them up but sensors are dead when I try with my Autel TS508WF. The bald tires on them have 2016 date codes so I planned to just do new anyway. $150 for 4 factory rims matching what she has couldn't pass up.
Go with the sensor units. I worked for a Lexus dealership and I never heard any issues.
