Lexus ES350 transmission drain/fill
Austin, TX
I have a 2011 Lexus ES350 and I have searched the WWW and haven't found instructions to do a drain/fill of the transmission.
If anyone has done a drain/fill on a ES350 sealed transmission could that be posted to this thread.
I have heard the same transmission goes with Camry/Avalon, so Toyo folks could also chime in...
If it doesn't have a drain plug then it should have a dipstick tube, if that is the case you need to buy a fluid extractor such as Mityvac to siphon ATF via the dipstick tube.
Well it has a drain plug and a bunch of hex bolts on the transmission (2 hex bolts). If I am not wrong some sealed transmissions are designed in a way that one fills until it overflows from the other bolt.
Too much tech into this vehicle is spooking my limited plain vanila preventive maintaince thought process.
My thought, and reason for asking, is that by idling the engine with a cooler line disconnected, you can pump the fluid out using the transmission's own pump.
Roughly, connect a clear plastic tube to the cooler line, place in a container on which you have marked a 2 QT line. Idle the engine until 2 qts have been pumped out. Shut it off, refill, and repeat until the fluid is nice and clear.
This has the advantage of getting all the fluid out (including the convertor). And you would have to refill through that hex bolt (instead of through the dipstick tube).
On yours though, sheesh...I have never dealt with one of these...drain and refill I guess, but I would want to know if the refill level (hex bolt) was for cold or hot...hot, I would imagine...
My BIL is a GM powertrain engineer...they design them this way because in many of the transmissions that fail, the analysis shows contamination....so, the larger threat to the trans is not wear or fluid breakdown...it's maintenance! The largest contaminant? Rag lint...red in color...shop rags...who knew?
I am with you - they want to get the trans through warranty without failures - but we want it to last longer...
