I have a 95 lexus gs300 with around 163k on the transmission, currently running auto rx in the motor and plan to do so in the transmission in the future. I was looking at the transmission fluid calculator and had a question
According to the calculator, since my transmission holds 8.3qts
and a drain and fill is 2 qts, I will need to do around 12-13 drain and fills to get new fluid
Can I do the drain and fills back to back in one session, or do i do a drain and fill, drive, then do it again. 13 drain and fills is alot to do but I dont want to risk this transmission by doing a flush
THanks
THanks
