One thing I am curious about on these sealed trannies using WS fluid:
They all seem to require or specify a fairly exact temperature range for checking the fluid level. What is it about these transmissions that requires this? Even on dipstick equipped models, I've not seen any that require this special procedure for getting an exact temperature range before checking. Most models with a dipstick simply say the fluid should be checked warm with the engine idling in Park.
What is it that requires such a specific temperature range? Why don't they simply have the procedure written with the "engine warm" like dipstick equipped models?
I will be changing the ATF (WS) on my 2006 Tundra 4.7 4WD Double Cab, equipped with the towing package, in a month or so, when it reaches 60,000 miles. I intend to use Amsoil ATL.
I had the current (factory) fill of WS analyzed by Blackstone at 15,011 miles, and at 30,146 miles. The viscosity readings, in cSt @100 degrees C was 5.00 and 4.89, respectively, so it does appear to have sheared some. I intend to pull a sample before changing it at 60K miles, and will post the results in the reports forum for transmissions.
