Let’s change the “thick vs. thin” up a little: Mercon LV vs ULV!
So why doesn't GM spec the Dex HP for the big new HD 10 speeds? The trucks they're in aren't subject to any CAFE rules. The customers who buy them are way more concerned with durability than a tenth of a MPG. They sure went to a lot of trouble putting massive coolers on the trucks and programming in a warm up drag (the transmission fluid heats up faster than the engine at start up). Seems to me like GM sure cares about viscosity.
As for the fleet guy, he listened to his oil supplier who (wrongly) recommended the fluid, a fluid sold as a fits all (with a D6 lic). Many fluid providers still do this (Big A incl) for this particular transmission.
Right... then, what's this? ⬇️
Well obviously the change from LV (6cSt) to ULV (4.5cSt) was in the name of increased drive line efficiency but the additive chemistry was enhanced such that we had to incorporate new Anti-Wear and Friction Modification chemistry along with higher percentages of Group IV and V base oils in the final formulation.
Is a MV DI package that is ULV compatible also backwards compatible with Dexron 6, Dexron III, and so on, as far as anti wear additives and friction modification chemistry are concerned?
Is a MV DI package that is ULV compatible also backwards compatible with Dexron 6, Dexron III, and son, as far as anti wear additives and friction modification chemistry are concerned?
Well, it could be. Extensive analysis would determine if the compatibility is there.
Or it could be by design, right? Like certain MV DI packages that Infineum and Lubrizol offer. A blender will not purchase three different additive packages to blend three different ATF viscosities. Instead, they will buy one additive package that has wide compatibility with most step-shift automatic transmissions.
@meep has experience in his 10R80 with a thicker fluid, it was not great.
Viscosity seems to be important in the 10 speed units as it has a pretty big effect on their shift timings. There are 6 clutches and solenoids in there that need to do a fair bit of gymnastics to pull off smooth shifts and it looks like thicker fluids slow that down enough to make things clunky. (Mine is a little clunky when it is cold out, but smooths out greatly when its at operating temp. This tells me enough about higher viscosities and shift timings that I don't want to mess with it)
Also, this being BITOG, I assume everyone is going to throw the 150k OCI right out the window. I do 10k D&F's and will stick with that as long as I own the truck.
I'm sticking with ULV's in my 10R80. Everything with mine is working as it should and I see no reason to mess with that. Even towing as heavy as I do my temps are well under control and the trans does what it is supposed to. I've so far used the Valvoline product, but it has shot up in price and I picked up a stash of Mercon. After that I'll probably go with HPL and stretch the OCI out some.
I am adding a PPE pan though in the next couple months, just for the drain plug, since sucking the fluid out is a bit of a pain.
I am eyeballing the PPE deep pan as well. Have you bought yours yet?
Mine calls for ULV - can’t think of but one reason, right ?
CAFE
[Edit]
I never said anything bad about ULV. My point was that it's not the viscosity of the fluid that matters for the 10-speed transmissions, as much as it is the friction modification chemistry and ATF formulation.
So, in your opinion, if the same AW/FM that is used in the ULV is used in an LV-viscosity fluid, would this have satisfied all other requirements that you had to achieve with the final formulation?
You don't mix DI ATF additive packages, ever. Some DI ATF additive packages are for MV applications, some are suited for LV, and others for ULV, but they are disparate DI additive packages.
I'm going to do just the regular pan. Haven't bought it yet, probably will in the next couple weeks. Waiting for some more Amazon points to rack up. I was going to do it at 60k, but I'm approaching 40, and I have the filter on hand, I might as well do it and get it done.
There's a guy on the Ranger forum that's doing a bespoke dipstick for us, that will hopefully come in slightly under the B&M $220 piece as well, but come pre-calibrated, so I want to do that as well, but I don't think he's going to have them done by then.
You don't mix DI additive ATF packages, ever.
I did not say anything about mixing.
Some DI additive ATF packages are for MV applications, some are suited for LV, and others for ULV, but they are disparate DI additive packages.
That depends on the MV additive package. Otherwise we wouldn't have things like Valvoline MaxLife that's backwards compatible with older transmissions calling for Dexron III-era fluids. Infineum makes at least one additive package for step shift automatic transmissions that's compatible across the board, all the way down to ULV.
Where did you get your filter from and how much did it run?
I would like a dipstick too, but there’s zero chance in Hades I’m going to pay 2 Benjamin’s for one. IMO, if a trans isn’t leaking, a transmission does not consume trans fluid, so if the level is set properly at the service time, you should be OK. 👍🏻
