As far as Ford goes with the 10R60/10R80/10R140
https://gearsmagazine.com/magazine/...0r140-10r80-and-10r60-the-same-but-different/
"WHAT THEY HAVE IN COMMON
The one component with the slightest variance is the valve body. The basic assembly is the same but cannot interchange between the variants. All units share the CIDAS (Casting- Integrated Direct Acting Solenoid), Pressure Control, and Torque Converter Clutch solenoids (figure 5).
While the solenoids are all position-sensitive, the OEM replacement is the same base part number for all variants.
Shift strategy is another item shared in the 10R family. Skip-shifting is normal and dependent on throttle demand and other load factors. Not all ranges will be selected in sequence on the upshift or downshift. For example, if you take off from a stop under moderate throttle pressure, you may experience a 1-3-5-7-8-9-10 shift sequence. A similar scenario may occur on deceleration. The TCM programming algorithm is designed to work seamlessly with the engine to produce nearly unperceivable shifts while providing the correct ratio given driver demand and driving conditions.
Torque converter scheduling is designed for maximum fuel efficiency. As a result, the converter clutch apply is noticeably delayed for smaller displacement engines compared to larger high-torque engines.
Normal operating temperature is a curious subject for discussion for these units. We have spent our whole transmission career trying to find ways to keep our units cool. Our mantra is the cooler the transmission runs, the longer it will live, right? Well, that goes out the door with these units! The normal operating temperature range for the 10R applications is 195°F to 215°F (90°C to 101°C). Yes, this is the OEM specified range, so don’t correct it. Everything from the friction and steel plates to the fluid is designed to function at its optimal level when the unit reaches this range. So, on a hot Arizona day, when you are pulling a 40-foot trailer uphill to the lake, it is common to see temperatures spike as high as 230°F!"
