Greetings:
My dad's '95 S10 fell victim to a large deer this week. He is looking to replace it with a late 90s-early 2000s 1/2 ton pickup. He would prefer a V8 automatic extended cab; 4WD is not a necessity as this will be used as a secondary vehicle. I wanted to see if anyone had any feedback on what to look out for on the usual suspects. This is what little I know from Google searches:
Ford: 4.6 and 5.4 V8 spark plug thread issues where engine spits out plugs. Potential $$$$ to repair. Transmission problems before '98 (accumulator piston, torque converter.) I am not sure if the 4.6 plastic intake coolant crossover issue (i.e. Crown Vics) applies to them.
Dodge: Front end problems (bad ball joints.) Some report transmission problems as well (related to governor pressure sensor and solenoid.)
Chevy: Transmission valve body and general electrical issues (fuel pump, climate control module, etc.)
When I look at underhood photos of the three, the Chevy looks like it is the easiest to work on and the Ford the hardest. All three look like they can rust in areas where salt is used on the roads(not a surprise).
Any feedback is appreciated!
Thanks,
Andrew S.
Thanks,
Andrew S.
