Its time to do my floors. Going over a concrete slab. Will be using a vapor barrier, quality padding, and I'd like to use a 12mm plank.
Question is this: How much of a"real" difference does thickness of the laminate make?
Will sound transfer and feel be noticably different between an 8mm plank vs. a 12 mm plank?
I know LOTS of you have experience here, so I'm looking for all opinions. The only reason I want to know is due to the fact that some of the flooring I like doesn't come as thick as 12mm
Oh and one more thing, is pre-attached padding any worse then roll out padding?
