My "qualifications" for this thread: There are about 6500 miles on my Neon's 2nd set of Kumho tires now.
The first set was the now discontinued Ecsta HP4 716, H-rated(Kumho has replaced this with something very similar), size 195/60/14, mounted on 14"x6" Mopar alloys. They lasted about 40,000 miles with minimal care, and from that standpoint were very good. As far as cornering, they had truly wimpy sidewalls compared to the previous tires(BF Goodrich Comp T/A H-rated), and even when inflated up to 36-38 psi didn't perform as well as the BFG's. Bought the Kumho 716's from Tirerack, will never do that again. When you lose free rotation & rebalance, you lose more than you save. Your decision may vary.
The current tires are Kumho PowerStar 758's in 185/65/14(the original factory size, whether on 6" wide alloys or 5.5" wide steel wheels), T-rated, again mounted on the same 6" wide alloys. Just got them rotated last week, gonna have to get them to check balance on the front ones very soon.
They were the cheapest thing in my size easily available in my area, bought them from Discount Tire in Longview, Tx.
Cornering ability is somewhat disappointing, but then I didn't expect them to be great. My #1 impression- for driving feel, and especially for tracking ability at highway speeds, these tires are more sensitive to air pressure than anything else I've ever driven on. Period, no contest. Rear pressure doesn't seem to matter, but the *front*! The tire shop let them down to their brainwashed 32 psi last week when hot. I checked them "cold" the next morning, the old reliable Milton gauge said 27-28 psi!
No wonder it felt so mushy & meandering on the way home. Up to & including the recommended 32 psi, they feel sort of mushy on the highway, feel like they might peel off the rim when pushed around corners, and track poorly. At a cold 36-37 psi(where all my other tires on this car have both handled & tracked the best), they cut & corner semi-OK for a cheap tire- but won't track worth a d___!
For these tires on my car with my gauge, the magic front tire figure is 34 psi cold. Feels like a completely different car, tracks almost like it's on rails, corners as well as the higher pressures. My guess- This pressure must give the flattest footprint for the tread.
My take on Kumhos so far- as a bang-for-the-buck tire, they're OK to almost-very-good. I'm still surprised at how sensitive the Powerstar 758's are to inflation- at age 53 I've never seen anything quite like it. It sounds like bull, but it's true.
