Originally Posted By: Bror Jace
gd9704, do you do yearly oil and filter changes?
Because while I'll agree with
Pete591 that the Amsoil 4-cycle 30/10W-30 would be a good choice, plenty of oils will be fine for 25-30 hours per year and dumping the oil (and filter) after such a short interval is kind of a waste.
I'd stick with a mineral oil ... and if you are getting zero consumption with 10w30, I'd stick with it. So, which mineral 10w30? I think an HDEO is about as good as you can do. Consider Pennzoil Long Life:
http://www.pennzoil.com/products/LongLife/index.html
or Shell Rotella 10w30.
http://www.shell.com/home/Framework?site...tellamulti.html
These can be tricky to find in 10w30 ... have Tractor & Supply stores near you? There's a chance there.
Otherwise I would use one of the "High Mileage" 10w30s ... which will be easier to find. I like Havoline High Mileage, Pennzoil High Mileage or Valvoline Max-Life. These are a tad thicker than most 30 weights and have more anti-wear and detergent/dispersant additives.
I assume you change the filter each year? I think Wix filters are about as good as you can get ... but you can probably find Purolator filters for half the price and for an interval of 25-30 hours, your Kohler will never know the difference.
Bror Jace,
Yep, this is a yearly change situation.
The Amsoil ASE looks like fantastic stuff, and I may get some for my Honda Genset (no filter), but I feel like it may be overkill for the Command engine.
I will look into the HD oils you've suggested, and see if they are locally available.
Perhaps a more HD oil will get rid of that occasional lifter noise.
