Then it must be true!He read it on the internetz.
Flathead briggs are worn out after about 400hrsSomeone correct me if I'm wrong but all small engines that I'm familiar with are flat tappet.
My command has hydraulic lifters, but others have "solid" flat tappets.
But to add a little more info - not only are the springs super weak, but their load is distributed over a big area.. the lifters in my command measure .842" which is the same size as the old small and big block Chevy v8s. In fact they look identical to a SBC lifter. The tappets in many others are similar sized or bigger (pretty sure flat head Briggs are about an inch) so they simply are not sensitive to zinc/phosphorus levels. Heck even passenger cars with stock valvetrains aren't THAT particular and they are sporting probably 5 times the spring pressure.
I had 700hours on my 17.5hp command running nothing but what PCMO I found on the shelf at the parts store. It wasn't until a couple of years ago that I bought the Kohler sauce to appease my wife who took over using it
Just loss of power. Still ran fine just didn't have the power it used to. Could have been a valve issue, idk.Worn out how?
No oil will save an engine from poor design and/or metallurgy and poor maintenance (like poor air filtration causing dusting), especially Briggs with their aluminum bores.Just loss of power
I know. The old flathead briggs or actually any aluminum bore engine only has a lifespan of about 500hrs or so. I just assumes the bore had too much wear becaise it's only aluminum.No oil will save an engine from poor design and/or metallurgy and poor maintenance (like poor air filtration causing dusting), especially Briggs with their aluminum bores.
To be honest I'm really surprised that they last as long as they do! Say what you want about Briggs but they knew the realities of a big part of the market that they sold to and made an engine that would probably still be humming along when the mower got tossed.I know. The old flathead briggs or actually any aluminum bore engine only has a lifespan of about 500hrs or so. I just assumes the bore had too much wear becaise it's only aluminum.
