- Joined
- Sep 12, 2024
- Messages
- 2
First post here looking for some help. This thing has been driving me up a wall.
Put a mikuni carb on my 25hp Kohler Command that powers my boat.
First trial run it would idle perfect but under 50% throttle and 100% throttle it would cut off after about 20 seconds.
Last time I had it out…. About a week ago (only thing I did was unplug the oil pressure sensor) it ran like a dream and I figured for some reason it was fixed.
Took it out today and it’s the same thing, 50% throttle and 100% throttle it cuts off.
It smells like it’s running a little rich but it dies like it’s running out of fuel.
I have a 12V HEP-02A electric pump rated at 2.5-4psi going into a pressure regulator set at 1.5psi with a return line between the pressure regulator and the carb for unused fuel to return to the fuel tank.
I was going to replace the flywheel and lifters since others before had suggested that since it runs right around 4000 rpm wide open but I’m not sure if that would cause it to cut off at ~2800 rpm like it is at 50% throttle.
I have some videos of it running and can take some pictures if the fuel pump/pressure regulator setup as well.
Thanks y’all.
Thanks y’all.
