This is where you don’t understand the concept. Properly tuned engines do have some pre ignition/ detonation. If they don’t, they are not optimized. Over time, this Kohler engine will start to wear and have blow by and will start to accumulate carbon. The additional oil blow by does lowers the octane in the mixture and the carbon deposits increase pre ignition, this leads to higher CHT and lower EGT. Higher CHT increase pre ignition even more and so on, that is why many call detonation ”cancer”, you have to deal with it before fatality. Using higher than recommended octane gasoline compensate for these issues by resisting to preignition (which you agreed), therefore lowering CHT and increasing EGT.
It is true that higher octane doesn’t burn slower. This is misconception because higher octane does affect the combustion timing, which give the APPEARANCE of a slower burn. Backyard mechanics who dont really know the difference would just say that is burn slower because it kinda does make sense to them. Now, bitog parrots would just keep repeating the same thing over and over trying to police the facts, unfortunately they don’t understand the concept, context and why people say that.
It is true that higher octane doesn’t have more power. This is misconception because higher octane prevent excessive ignition retard from ecu, which give the APPEARANCE of more power. Again, people who don’t know the difference would just say that premium gasoline have more power because it kinda does in specific context. A brand new Focus RS had 350hp on 93, but had less power with 91 because the ecu pulled timing, same thing with STI and other high performance cars.
Many people have experienced an old engine that would run better with premium gasoline.
That being said, if someone has an engine running poorly with very high CHT, premium gasoline will not save him, but the concept is still valid.
In this thread, 300f is far from hot and I bet he could run 87 octane without issue because the engine doesn’t experience too much pre ignition/detonation, but the concept is still valid.
If someone wants to experiment, CHT sensors are cheap and take seconds to install while changing the spark plug.
