Anybody know why Costco, isn't carrying Kirkland signature 5W-20 synthetic oil in 6 quart cases?
That sucksNope. Only seen 10qt boxes. 5 qt jugs x2.
They don't even have 0w20 all they have is 5W30.Bc 0W20 > 5w20
They did but I have noticed their stock diminishing lately.They don't even have 0w20 all they have is 5W30.
https://www.walmart.com/ip/Quaker-State-Full-Synthetic-5W-20-Motor-Oil-5-Quart/14958323I guess I'll be trying Supertech or Amazon basics.
Never been a fan of Quaker State or Pennzoil. Probably because, of all the **** that happened way back when, but now if you look, at the oil test results, for Kirkland and Quaker State, Kirkland has better specs?
Have all of it in the garage. I'd say the QS and Kirkland are pretty similar. Kirkland more affordable.Never been a fan of Quaker State or Pennzoil. Probably because, of all the **** that happened way back when, but now if you look, at the oil test results, for Kirkland and Quaker State, Kirkland has better specs?
They're comparable in many respects; both are D1G2-rated.Never been a fan of Quaker State or Pennzoil. Probably because, of all the **** that happened way back when, but now if you look, at the oil test results, for Kirkland and Quaker State, Kirkland has better specs?
https://pqia.org/Which oil tests are you referring to?
But it also shows what is a more premium oil..Those tests show that the oil is serviceable and meets the specs as defined.
Nail it down for us just how many more 10's of thousands of miles is it going to make your engine last?I'm not saying Quaker State is not a premium oil, my debate was that Kirkland was a better oil.
