Originally Posted By: timur38
Thanks 69Torino, so there are no advantages of using 5w-40 in 2.0 turbo engine?
Really only in hot climates will be an advantage with a 40 weight. You won't hurt anything but your fuel mileage. Anywhere that gets under 70 degrees F will be doing well to have a good synthetic Xw-30 synthetic, especially name brand with manufacturers approvals.
You can absolutely use 0 or 5w-30 in the 2.4 non-turbo engine, but never 0 or 5w-20 in a 2.0 T-GDI. Only 30 weight or better, and they seem to have good power and fuel mileage on 30 weight oils vs 40 weights. The variable valve timing reacts much quicker on thinner oils, which translates into better low end torque "feel", due to the quicker moving cam phasers. In my humble opinion, oil flow is vastly more important than oil pressure or using a higher viscosity to make you feel better inside. Faster oil flow is also good for bearing cooling, both in the main and rod bearings and the turbo bushings. These turbos have bronze bushings, not bearings. They LOVE oil flow. I have a failed turbo shaft/wheel assembly in my garage, I'll try to post a pic of it tonight. Bronze transferred to the shaft and it became very noisy and barely produced boost pressure.
