Just saw this oil at Walmart today.
KS
Properties and Specifications​
PropertyMOBIL DELVAC HDEO 10w30MOBIL DELVAC HDEO 15W-40
GradeSAE 10w30SAE 15w40
Ash, Sulfated, mass%, ASTM D87411
Cold-Cranking Simulator, Apparent Viscosity @ -20 C, mPa.s, ASTM D5293 5900
Cold-Cranking Simulator, Apparent Viscosity @ -25 C, mPa.s, ASTM D52936550
Flash Point, Cleveland Open Cup, °C, ASTM D92225225
Hi-Temp Hi-Shear Viscosity @ 150 C 1x10(6) sec(-1), mPa.s, ASTM D46833.64
Kinematic Viscosity @ 100 C, mm2/s, ASTM D44512.014.2
Kinematic Viscosity @ 40 C, mm2/s, ASTM D44582112
Mini-Rotary Viscometer, Yield Stress, -25 C, Pa, ASTM D4684 20000
Mini-Rotary Viscometer, Yield Stress, -30 C, Pa, ASTM D468422600
Pour Point, °C, ASTM D97-36-27
Specific Gravity, 15.6 C/15.6 C, ASTM D40520.8670.874
Total Base Number, mgKOH/g, ASTM D28961010
Viscosity Index, ASTM D2270140132
the 15w40 was ten dollars at my walmart. I would have bought it and use it but its april and snowed yesterday and the 15 day forcast still says freezing temps at night in chicago
maybe I should listen to the wife and move to hawaii LOL
15w40 is generally acceptable down to 20F, is it not? That's what I've always understood. Personally, I wouldn't have an issue running a syn blend or Full Synthetic version down to 0F.
I just looked at the bottle tonight. The only thing that jumped out at me was it wasn't gasoline rated.
I saw this at Walmart in New Mexico today. Today they had Delvac 1300 along side the new stuff. Would this be ok to use in my LMM Duramax if they are out of the 1300
It looks like Mobil has renamed Mobil Delvac 1300 Super as Mobil Delvac HDEO.
However, this also seems more to be an international name rather than a US name.
No, this is a different product, Delvac 1300 Super still exists, and it's mixed fleet oil, this is diesel only oil and has to have above 1000ppm of phos because it's got the ford approval.
I see.
Detailed specs for Delvac HDEO:
https://www.mobil.com/en-mx/commercial-vehicle-lube/pds/na-xx-mobil-delvac-hdeo-series
Detailed specs for Delvac 1300 Super:
https://www.mobil.com/en-us/commercial-vehicle-lube/pds/gl-xx-mobil-delvac-1300-super-series
Delvac HDEO has a more stout add pack at the expense of not having a certification for API SN but adds the Ford certification as you said.
Delvac HDEO 15w40 CK-4 is slightly thinner than Delvac 1300 Super 15w40 in terms of base oil. This translates as better wear protection for Delvac 1300 Super, but Delvac HDEO could possibly make up for it through its more stout add pack.
Estimated base-oil viscosity and VII content of selected oils
